View Poll Results: Grand Am Cup Cam vs. T-Rex Killer
Grand Am Cup Cam
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
24
42.11%
T-Rex Killer
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
33
57.89%
Voters: 57. You may not vote on this poll
#61
Originally Posted by DEEZ98Z
Here is my set up....
Fast 78mm (going to 90/90 set up soon)
EB Porting 5.3 heads (11.3 to 1 compression)
Trex killer cam
4L80E w/ 11" converter (changing out soon)
12 bolt w/ posi and 3.73's
Put down
442 RWHP / 400 RWTQ on a Mustang Dyno (set up for DynoJet numbers)
I think that I will be able to come in around 460-470 with a new 9.5" converter and 90/90 set up.
Trex killer cam
Put down
#62
Originally Posted by BAIN
Are those #'s through an unlocked or locked converter?
What kind of power did you put down with the Trex cam? What trans and all that....
#65
Originally Posted by MountainMotor
How's the Rex Killer in the low-end? I figure it won't have a lot until around 3000rpm's but just wanting to see how it feels?
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#66
That is locked. Unlocked it was 420....
#67
I put down 423 locked with stock heads, Fast 90/90, Hooker Lt's, 3" duals, and most the other bolt-on's. I have a power robbing drivetrain (50 hp difference unlocked vs locked) and low gears. The tranny is a Rock-On built 4l60e with a Yank PT4800 converter and the rear is a built 8.8 with a 4.30 gear.
#68
Originally Posted by calongo_SS
As far as the so called "T rex Killer" give me a fuggin break. Any of the fastest cam only cars running this cam? Perhaps a marketing scheme? If you want an all out drag cam I'd go with something proven, which the t rex killer, IMO, is far from.
Get your facts straight, the cam he's talking about is LS1Joe's. Joe's car made 460+ r.w.h.p. cam only, through a 12 bolt with 4:56's, and has run 10.23 Marketing scheme,
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#69
From what I know about LS1Joe's setup, the heads have never been off the car. He is making killer power cam only, and running the times to back it up. I am willing to be that if it wasn't for that 9 inch, gears, and slicks, that his car would put down close to 500 cam only. Joe is also a helluva tuner!
#70
i do believe that he is shifting north of 7,200, as well. killer numbers, but shifting over 7k on a factory shortblock with rod bolts or not is borrowed time. i would assume he is on thin ice with that tune, also. but isn't he still a couple hundred lbs heavier than the t-rex car? i'd like to see some results after more weight is found and eliminated.
#71
Well yes I shift well north of 7,200 rpm but on borrowed time? My short block has well over 400 drag strip passes and I believe if you take care of it, there is no reason it will last. I have shead quite a few pounds and will be sheadding more this week. I ran a 10.37 on Saturday in Bowling Green at the NMCA race with 70lbs in the car for qualifying.
I am adding some goodies to my car that should pick up the numbers well above 20rwhp and will be sheadding all of the weight that I can.
My tune is very conservative and I would not hesitate to tune other cars just like mine. I could easily pickup another hp or two by going crazy but why. The car is consistant and runs the number.
Also I have a 9" and I made 463rwhp thru slicks, 4.71 gear and 90 degree weather.
Oh and by the way It is a 425 shot![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks,
LS1Joe
Thanks,
LS1Joe
#73
Originally Posted by orangeapeel
This thing is still around?
voting trolls must have dug it up.
