how to block off the hole on top of fbody intake?
Old Dec 21, 2005 | 09:55 AM
TT_Vert's Avatar
Default how to block off the hole on top of fbody intake?
Im putting this onto a car that wont have the provisions for that tube. Is there some form of blockoff plate? if so, where can I get it?
Thanks
Dave
Old Dec 21, 2005 | 10:08 AM
SuperGook's Avatar
from my understanding you can just go buy an adjustable plug from the autoparts store, kinda like those expandable freeze plugs. hope that helps
Old Dec 21, 2005 | 10:29 AM
Camaro99SS's Avatar
I used 2 spark plug gapping tools, one to cover the hole, and the other with a bolt going through the other at an angle to hold it down. It was ghetto, but it worked well until I put the LS6 on.
Jason
Old Dec 21, 2005 | 10:45 AM
thunderstruck's Avatar
i think i used a 1 7/8" expandable freezeplug from autozone. didnt look the best though
Old Dec 21, 2005 | 10:51 AM
00scss's Avatar
If you are talking about the egr hole, there is a specific plug. You can get at the dealership. However, it will not show up in the parts dept. pic, it will be in a note down at the bottom.
Old Dec 21, 2005 | 11:12 AM
TT_Vert's Avatar
do you have a part #?
Dave
Old Dec 21, 2005 | 12:19 PM
Krab's Avatar
You can also put a block off plate on it, but the freeze plug probably seals better.
Old Dec 21, 2005 | 12:22 PM
fugasi's Avatar
Just do the freeze plug... Much cheaper and works like a charm. Doesn't look terrible either, it'll just be noticible to anybody that knows what to look for.
soul strife's Avatar
It is the 1 7/8" expandable freeze plug. It's cheap and seals better than just about everything else. That's what I used until the new intake. Good Luck.
Old Dec 21, 2005 | 12:57 PM
TT_Vert's Avatar
is the hole actually 1 7/8"? So I can pound a 1 7/8" freeze plug in?
Dave
Old Dec 21, 2005 | 01:01 PM
Don't pound a freeze plug in! You'll get plastic shavings in the intake. Get the 1 7/8" Expansion plug. It has a screw that will make the plug expand to fill the hole completely. It looks like a thick rubber gasket with a metel plate on each end.
Old Dec 21, 2005 | 01:03 PM
TT_Vert's Avatar
ill take the intake off and blow out the shavings. or take off TB and vacuum it out. Is 1 7/8" a tight fit?
Dave
Old Dec 21, 2005 | 01:08 PM
So, You'd rather go through the hassle of taking off your intake. Pound on a freeze plug which depth is shorter than an expantion plug and won't give you as good a seal and then blow out the shavings. Or, Use an expantion plug get a good seal from the thicker rubber and spend a total of 20 sec. to install it. ( 10 sec. of that opening up a pop).
Your choice. I know what I'd pick.
Old Dec 21, 2005 | 01:09 PM
fugasi's Avatar
The EGR opening is smaller than the 1 7/8" plug. Just put the plug in and start tightening the bolt down. The rubber grommet will start to expanded out and seal the EGR opening.
Old Dec 21, 2005 | 01:15 PM
TT_Vert's Avatar
yes, its all about appearance. taking the intake off will take me 5 minutes. Engine is out of car.
Dave
TT_Vert's Avatar
what is the diamter of the hole and has anyone actually used a brass or steel freeze plug in the hole w/ nothing else?
Dave
Old Dec 21, 2005 | 01:16 PM
nddragon01's Avatar
Mine took 25 sec. I opened a beer instead, and before installing the plug, raced my cousin in downing our beers . I lost, but still got the plug in within 25 sec.
Old Dec 21, 2005 | 01:20 PM
Lol!!
Old Dec 21, 2005 | 01:24 PM
2xLS1's Avatar
The size is 1 3/8", not 1 7/8. Why screw with anything else when these are $3 and work so well.
Attached Thumbnails how to block off the hole on top of fbody intake?-expplug.jpe
Old Dec 21, 2005 | 01:29 PM
TT_Vert's Avatar
the expanding plug looks like crap, Dave..
Dave
