Heads And Cam
Old Dec 25, 2005 | 04:20 AM
SatanzWS6's Avatar
Default Heads And Cam
what heads/cam setup do you guys recommend for an A4 WS6? im lookin for a setup that is good enough to get me into the low 12's high 11's(if better, than thats cool too). i know i'll need a converter to help out but i want to get a heads/cam first. it will see the track occassionally, but i want somethin for street racing. yes it is my daily driver, and gas mileage is not an issue. i plan to someday get a turbo or spray, maybe both. any input is greatly appreciated. TIA
Old Dec 25, 2005 | 10:27 AM
mrr23's Avatar
AFR 205 heads and vinci 055 cam
it's what they used in the project AFR corvette to get there. i'm sure you can do better with the f-body.
Old Dec 25, 2005 | 02:07 PM
SSilverSSurfer's Avatar
you do a cam and converter and be in the 11's...no need for heads and unless you really want them....i went 12.1-12.2 with a cam and LT's....now i went with a bigger cam and converter
Old Dec 25, 2005 | 02:10 PM
BlackHawk T/A's Avatar
No need for heads...blasphemy!
If you want the most out of any cam you need heads to match. An engine is an air pump...match all the components and they all work together.
Old Dec 25, 2005 | 02:53 PM
8banger's Avatar
I am running a cam only setup and probably will be until at least next year. I'd like to see what I can do. That said, if I could afford the heads I want right now, I would have them. Heads do help. Not only do they free up more horsepower, they significantly increase torque and power under the curve. For what you want to do, here is what I would recommend...I'd go with AFR 205's no matter what, but I'm recommended three different cams depending on what you want...and listing matching stalls:
1. Mild idle, stealthy
-AFR 205's
-AFR 224/228 cam
-3500ish stall
2. Good power, midrange/top end (I'm running the same cam and stall)
-AFR 205's
-G5X2 (232/240, .595/.608, 114)
-3800ish stall
3. BIG power, NASTY top end, decent idle
-AFR 205's
-HPE 'S' cam (238/242, .608/.612, 115)
-4000+ stall
I would go with any of these three. Keep in mind, none of them will be great without a converter. Setup 2 and 3 would also be awesome if you want to spray.
Old Dec 25, 2005 | 04:13 PM
ATLHwyRacer's Avatar
What 8banger was talking about on #3 I was running 10.8's consitant 2 years ago w/ a similar cam (239/242 109lsa), MTI Stage 1 heads and a 4000 stall.
Old Dec 26, 2005 | 02:51 AM
SatanzWS6's Avatar
so if i get HPE's "S" cam, what else would i need to get? sorry for the newb question , but im just a newb tryin to learn all i can about these cars.
Old Dec 26, 2005 | 02:57 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
We all are! That is why this place exists!
