TSP Torquer 2 too big for a Daily Driver?
Kinda taking side to CheaTR because of its near perfect drivability, stealth and it works with stock exhaust manifolds. Also, CheaTR will need no tuning as I learned.
232/234, .595/.598 113+0
Very good in traffic (gas consumption went up), superb on HWY (Gas consumption went down).
If you drive it easy (normal) in traffic it is surprisingly tame. The only thing that makes it surge a bit, is off idle abrubt acceleration, followed by sudden stop. Only then does it hunt a bit for idle (like 2>3 seconds).
A good tune is what makes it or brake it and I'm still fine tuning, but I'm really impressed, especially that I swapped from a Stealth II cam that was very docile.
So you think a 114 lsa would do well? how does it affect the sound?
I can make a 116 cam idle like a mini dragster.
Sound doesn't make power.
112 will make power sooner and sound meaner but will be more difficult to tune and will give you less idle vacuum which is really needed in A4.More overlap
114 will make power later, sound smoother but give you plenty vacuum.Less overlap.
I went 113+0 to have a little of both (not to mention comfy PTV margins on my 2.04/1.575 valves)
A 114LSA will be more low/mid range with a top end that is a bit softer than a 112LSA.
112LSA will have an aggressive idle and suck up a little mpg.
I daily drive a TSP 233/239 112LSA .600/.603" lift cam (AFR 205's/LS6 intake/1 7/8" headers) with 3:90 gears/M6. From a start it isn't docile and needs a little gas to get going (I also have an alum flywheel).. but once moving it drives mellow at part throttle. At WOT above 4,000rpm it pulls hard to my 7100rpm redline. I like the cam a lot... may switch to a 228/228 114LSA over winter though to get a few mpg back and more mid range (I road race).
Higher duration cams 230*+ need deeper gears (ie 3:73/3:90/4:10/4:56).
112LSA has a narrower powerband and makes peak power sooner than a 114LSA. The tighter the LSA, the quicker peak power is reached and the narrower the powerband, with more overlap than a bigger LSA.
FM14 is on Cam Motion lobes with ramps of 50 intake and 51 exhaust IIRC.
Torquer V2 is XE-R with ramps of 49.
TroubledWine3 has got what I said correctly.
Here is a link to it idleing and revving!
http://media.putfile.com/Jons-Vette-w-LGs
