dropping the hammer from a roll...............
The color seems to be white-ish but maybe its a little dark. Its certyainly not black though.
Its tuning (plugs, programming, ignition) if its black.
I also get pure black soot that builds up on my bumper right over each tailpipe. It takes about 1 week to start getting real noticable after I clean it off.
What is that all about?
The first start of the morning I can see very faint puffs of white smoke coming out for about the first 20 seconds, than it stops and its clear.
Also, if I sit and idle in "park" and give it a good rev I'll get that same cloud of white-ish smoke, but if I rev it some more its almost all gone, just a little on each rev after the first.
Check inside the intake for oil. Flashlight..long swab.
What fixes this?
There is no exterior visual leaking anywhere, its been checked by two shops and the dealership. Everyone guesses its leaking into a cylinder from a partially blown head gasket.
Can this cause that smoke when I punch it?
Can it cause the pure black soot too?
It is running perfect, quiet, smooth and strong as hell though.
And this:
Originally Posted by felton316
If you have ported heads make sure there is some sort of sealant on the rocker arm bolt, or oil will run down it into the intake port of the head.
I wouldn't know where to begin to do that. I guess I should get a new tune and than I can have that checked."
It's really simple. You take off the valve covers, remove only the intake rocker bolts, put sealant on the threads and a little dab of locktite under the washer. Re-tighten to 22 ft/lbs.
But no white stuff at all, ever.
And this:
Regarding the oil, you need to drain it and look at it. The sludge is a sign as well although for me I can get sludge buildup by driving in the winter and not heating it up for over 20 minutes.
Will the pressure test determine which of the 3 things it is 100% for sure?
If I'm only loosing a cup of coolant per day at most how can it make such a cloud behind me, I would think a few ounces of coolant would get diluted easily in the mix.
NO antifreeze here.....just straight water. So how can just water even make a cloud?
