Compression Test results?
Old Dec 29, 2005 | 08:40 AM
Vertigo's Avatar
Default Compression Test #'s?
I am getting ready to do a compression and leakdown test tonight. I have been searching all over the place but have not found numbers to compair my results to. For example.. what would be bad, avg, good compression readings?
How is a leak down read? How many lbs of air do i put into a cylinder at TDC? Once i have air in there how do you measure leak %? Is is calculated over a period of time? Is a 98% leakdown good/bad 5%good/bad.
And from what i understand the following cylinders will be at TDC at the same time. 1&6, 8&5, 7&4, 3&2. Once you find 1&6 mark the 12oclock position on the crank pulley then rotate 90* gives you 8&5 at TDC, and so on...correct?
Thanks!
Old Dec 29, 2005 | 09:34 AM
'Trust''s Avatar
I dont know about leak down test but i know compression is like 160-180psi on normal motor and 180-210 on a more aggressive motor, anything below 100 is considered a dead cylinder
Old Dec 29, 2005 | 11:29 AM
Vertigo's Avatar
awesome! Thanks
Old Dec 29, 2005 | 02:55 PM
Joel_SS's Avatar
anything more than 10% leakdown on a cylinder and you got problems..
Old Dec 30, 2005 | 10:14 AM
2000TransAmWS6's Avatar
Thanks!
you're right, those cylinders are companion cylinders and will be at TDC (of their respective stroke) at the same time, but you have got to make sure that you're doing the test for each cylinder on TDC of the compression stroke, for the leakdown test.
if you're turning the crank 90* between each test make sure that you're testing the cylinders in the correct firing order (1-8-7-2-6-5-4-3). also, if you do not have the cylinder perfectly at TDC the compressed air will force the piston down. what we did at the school i went to was to put a long drinking straw in the spark plug hole and you see the straw stop moving at TDC. but remember that you'll be able to turn the crank shaft for a little bit before the piston will start traveling the opposite direction.
Old Dec 31, 2005 | 09:49 AM
Vertigo's Avatar
Great post! THanks!
