99-02 ls1 heads fit a 98 ls1
You also need to get head gaskets made for a 99-02 ls1. You will also need to do something about your coil packs. Either get a bracket to mount them on the center bolt covers (if they don't come with one) or you need to relocate them somewhere. Thunder sells relocation brackets.
let me see if i got this right.... i can use 99-02 heads as long as i use my 98 valve covers ?
I also think you will need to relocate your coil packs.
