Jesel's finally, ET solid roller pushrod length ect...
Old Dec 30, 2005 | 09:06 PM
Phil99vette's Avatar
7 Second Club
Default Jesel's finally, ET solid roller pushrod length ect...
After waiting almost 2 months for Jesel and rockers I said enough was enough. Called a couple of my old buddies and sure enough Brian had a set of Jesel J2k rockers that he had purchased to use on his C5. Called Brian on his cell phone wednesday night and told him to ship them over, 2 days later they were at my front door. Brian you are the man!
We mocked the setup up tonight and with the adjusters about centered in the adjustement range the pushrod length came to 7.855 which we will round to 7.850.
Old Dec 30, 2005 | 09:13 PM
DavidNJ's Avatar
A thing of beauty...is your wife jealous?
A few questions:
  1. Which lobes did you use?
  2. What valve springs did you use?
  3. What rocker ratio(s) did you use?
  4. What intake did you use?
Thanks,
David
Old Dec 30, 2005 | 09:22 PM
7 Second Club
A few questions:[list=1][*]Which lobes did you use?
Comp Solid
[*]What valve springs did you use?
PSI Solid, thinkin #1224
[*]What rocker ratio(s) did you use?
1.70, ~.650 lift
[*]What intake did you use?
Fast heavily ported
BTW, These heads are 225cc not the 240 solid roller for the 6 speed shop car.
Phil
Old Dec 30, 2005 | 10:09 PM
Beast96Z's Avatar
Are those gunna clear the stock valve covers, or did you get spacers. I remeber you talking about spacers before. Looks very nice. I have the lightened Mohawk series in the mail right now.
Old Dec 30, 2005 | 11:14 PM
gun5l1ng3r's Avatar
So is the increased pushrod length caused by a shorter solid lifter?
Old Dec 30, 2005 | 11:18 PM
Cary@Perf-Induction's Avatar
Collections Hold
Default rockers
Phil,
Same here, Maybe you can get me in touch with Brian,
We have about 8 sets of non adjustable rockers here now. Kinda sucks when we ordered 10 sets of adjustables. Also ordered a set of jesel lifters, .180 offset. Those got here right away, although they were striaght up on center. These are the kind of problems we've been dealing with for the last six months.
Good luck, I cant wait to see how it dynos.
cary
Old Dec 31, 2005 | 01:05 AM
Beast96Z's Avatar
I'm not sure how many things contribute to the longer PR, but I know the longer valves are one of them. I wonder why there is such a variance between PR legnths? I saw another guy who used 8.100's in his ET headed application. Phil, have you mocked up your 240's to see what there gunna need legnth wise?
After looking at those pictures again, it looks like they have alot more meat in the PR area, so that could contribute to why yours are shorter than someones with stock rockers.
Old Dec 31, 2005 | 03:23 AM
DavidNJ's Avatar
Comp Solid
1.70, ~.650 lift
Fast heavily ported
Phil
Thanks,
Which profile lobe?
PSI DR1224? 1,625" diameter, 2" tall, 275# on the seat, 750# over the nose (675# at .650 lift)? Does a 1.625: spring fit? Wouldn't that be a little stiff for a .650" lift?
David
Old Dec 31, 2005 | 05:10 AM
eallanboggs's Avatar
Damn if my rocker looked that good I'd have to install plexiglas rocker covers and a minicam w/monitor just so I could watch my rockers pivot as a drove down the highway. It must be a hurtin feelin bolting on the rocker cover over those beautiful Jesels knowing that no one will ever get to see them again. I couldn't tell from you photos, but are the rockers in pairs? If so, why don't they just make one long shaft to cover the entire pedestal on the heads instead of using 4 pairs per side?
Old Dec 31, 2005 | 08:27 AM
7 Second Club
I have a set of .500 spacers and its gonna be very very close. I think we're just going to cut out some aluminum and fab up some valve covers this weekend.
Phil
Old Dec 31, 2005 | 08:28 AM
7 Second Club
No, they are 11 degree heads and when you rotate the valve the pushrod needs to be longer to maintain correct valvetrain geometry.
Phil
Old Dec 31, 2005 | 08:29 AM
7 Second Club
You wouldn't be able to install them, due to the high spring pressures associated with solid roller valve trains you would break the shafts/trutions<sp>.
Phil
Old Dec 31, 2005 | 08:32 AM
7 Second Club
Originally Posted by DavidNJ
Thanks,
Which profile lobe?
David
David,
1.625 springs fit into the enlarged spring pockets.
Phil
Old Dec 31, 2005 | 10:59 AM
DavidNJ's Avatar
Which brings back the question: which lobe? 275# on the seat would support a pretty aggresive lobe, especially with a small 2.10 valve.
Old Dec 31, 2005 | 11:39 AM
CAT3's Avatar
Restricted User
That was my setup, using ETP 11* heads, Stock Rockers with ETP Stock Rocker Stands, Morel lifters, no milling and a .040" Cometic. Next time I'll go SR, since Phil is motivating me
Old Dec 31, 2005 | 12:09 PM
7 Second Club
ET 240cc heads
Jesel J2k Adjustable rockers
Lunati Solid lifters
Final Pushrod Length: 7.850
Tonight we're going to mock up:
ET 225cc heads
Stock Rockers
Comp Cams R lifters
Final Pushrod length:TBD
Old Dec 31, 2005 | 05:34 PM
CAT3's Avatar
Restricted User
Phil, make sure to either post or pm the results of the hyd. lifter setup. I am hoping you come out close to 8.100"...just for my own POM
Old Dec 31, 2005 | 07:28 PM
LASTLS1's Avatar
6 Second Club Moderator
Phil
I have two sets of valves covers that will fit if you need them. Andy.
Old Jan 2, 2006 | 02:21 PM
racecar's Avatar
That's some monster spring pressure, what RPM are you planning on running this motor ?
Old Jan 2, 2006 | 02:28 PM
LS1 BU's Avatar
Those look so pretty, I don't know if I would put them on a motor.
