head bolt TQ question...
Old Dec 31, 2005 | 12:08 AM
SVThis's Avatar
Default head bolt TQ question...
like the title says...how much do u TQ the head bolts?
Old Dec 31, 2005 | 12:10 AM
jrp's Avatar
jrp
SN95 Director
TQ specs are in the FAQ.
Old Dec 31, 2005 | 04:11 PM
SVThis's Avatar
didn't find it there
Old Dec 31, 2005 | 07:05 PM
jrp's Avatar
jrp
SN95 Director
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
Old Jan 1, 2006 | 01:33 PM
Haans249's Avatar
Just installed a set of heads with the help of a master mechanic. He said that 3 passes at 30 lbft, 50, then 70 will be fine in the proper sequences of course....will it?
Thanks!
Old Jan 1, 2006 | 01:40 PM
Haans249's Avatar
I'm also using the GM MLS .051 head gaskets
Old Jan 1, 2006 | 02:32 PM
Haans249's Avatar
If I were to re-trq them all, could I just loosen them all then trq them according to the trq sheet?
Thanks,
Adrian
Old Jan 1, 2006 | 02:48 PM
vettenuts's Avatar
The question is not clear, are these stock or ARP bolts. Stock only is tightened to a specified torque on pass one, subsequent passes are to specified rotations not torque values.
Old Jan 1, 2006 | 03:17 PM
Haans249's Avatar
Sorry, these are stock bolts
Adrian
Old Jan 1, 2006 | 05:42 PM
eallanboggs's Avatar
The bolts stretch once they reach their rated value so you can't retorque them and expect them to hold up for thousands of miles as I'm guessing you want them to do. You'll need ARPs to be able to get away with that trick. I put whiteout on the NEW bolt heads once I reached the specified torque value then turned them 75 degrees or something close to that in the proper sequence. Look on LS1HowTo. Goober could have gotten it right following those detailed instructions. Pitures and everything, in color too. Dawg gone!
Old Jan 1, 2006 | 11:51 PM
Haans249's Avatar
Well, i'm wondering if 70 ftlbs would be close to the final torque value once you do the 90 degree torque to yield. If I'm screwed here, I need to know asap so I can get new head bolts, or if it would be fine to loosen them, and then do the torque to yield because that would yield a higher torque value then 70 ftlbs.
Or, if I should try and turn all the bolts another 90 degrees......anyone know what final torque you'll get from that last pass at 90 degrees on the longer M11 bolts?
Thanks a lot!!
Adrian
Old Jan 2, 2006 | 12:06 AM
cowboysfan's Avatar
you should just remove all bolts and start frm begining w/ new bolts! better safe then sorry. "imo". no qeustion wil be unanswered.
fuerza ws6
Old Jan 2, 2006 | 12:25 AM
Haans249's Avatar
thats what i'm thinking, but i need to get it done tomorrow, so if there is some way to re-trq, or if it will be fine as is, that would be better
Old Jan 2, 2006 | 08:16 AM
vettenuts's Avatar
If you are using stock bolts, you need to put in new ones and follow the correct sequence. The sequence is also year dependent. My 02 Vette manual has two 90* rotations with the exception of two bolts that are taken to a different rotation on the second pass. If you used stock bolts and tightened to a torque value, don't start the car and re-do the bolts with new ones correctly.
