What size pushrods for heads milled 30 thousandths?
Old 12-31-2005, 11:14 AM
fastmatt98's Avatar
Default What size pushrods for heads milled 30 thousandths?
Is stock fine to use or would I need to go 7.350? Also would it rob me from hp if the size was wrong?
Thanks,
Matt
Old 12-31-2005, 01:07 PM
Beast96Z's Avatar
Originally Posted by fastmatt98
Is stock fine to use or would I need to go 7.325? Also would it rob me from hp if the size was wrong?
Thanks,
Matt
.030"? 7.350's are fine. 7.325's are far to short for that application. I have 2 sets of 7.350's FS if you need one. PM me if you do. Thanks
Old 12-31-2005, 01:32 PM
PREDATOR-Z's Avatar
What size (thickness) gasket are you using?
Old 12-31-2005, 03:23 PM
Moderator
davered00ss's Avatar
7.35" (w/stock gaskets), but gasket thickness can change that.
Quick Reply: What size pushrods for heads milled 30 thousandths?
