dropped sleeve...anyone got a picture
The way we did our sleeves, it is virtually imposible to drop a sleeve.. The sleeve is sitting on 2 flats we machine into the block, one at the deck and one at the bottom of the bore. Also the ARE blocks are all dry sleeves. I would think a head gasket is blown. If you start the car and look in the rad cap, can you see the coolant kinda of pulsating to the motor? This would mean its pushing past the gasket and pressurising the rad. Do a leak down test, and that should narrow it down... Let me know.
Originally Posted by kossuth
Honestly, I highly highly doubt it is a sleeve. A dropped sleeve will DESTROY the engine. Think about it this way. You have a large cube motor with a large stroke, they had to clearance the sleeve/bore for the rods and rod bolts as it is. If it (the sleeve) came any lower, the rods would smash into the bores. The engine would have torn itself apart. It sounds like it is eithor a bad head gasket, cracked block, bad seal around a sleeve, or a cracked head. Is any coolant in the pan? I wouldn't run it anymore until you find the source of the problem. Coolant in the oiling system tears bearings apart. Could even be a crossover tube or the plugs on the heads. Gotta look, don't want to f-up a 5k plus motor.
The motor cost me $12K
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Behind my car on the ground behind both tail pipes is water spatter marks. It comes out only on start up for a few seconds. Once I started my car than immediately walked to the back and opened my hatch and I felt it spraying on my legs. It really had no smell, just a little dark in color. Not oil either. I always thought it was condensation inside the exhaust from sitting over night. Maybe thats the leaky coolant from the gasket.
This rebuild you guys did for me has been friggin great man. The engine has been strong as *****, quiet and smooth since day one.
I was wondering why builders wouldn't machine a little step into the block for the sleeves to sit on, guess you're a few steps ahead on that one.
But I think I did blow a head gasket now that you (and the others) pretty much confirmed the sleeve couldn't have dropped any. I had alot of heating trouble this summer when I would run my A/C, the engine would run perfectly cool, zero detonation, on a hot *** day in traffic. But the second I turned the A/C on it would go right past the 210 degree mark in a matter of 4-5 minutes and the detonation was UNFUGGINBELIEVABLE. I would turn the A/C off and it would all the way back down under the 155 degree mark and run perfect again. I think I blew a gasket than.
I'm gonna have to have someone replace my gaskets I guess. Because other than adding a little water every few days, the engine is running like a gem.
Thanks Sled.
Did you check to see if the fans were instantly coming on when the A/C was turned on? If th eA/C is on, one fan should always be on. Maybe that one isn't working causing you to over heat. Really sounds like a slightly blown gasket. Like the others said, have a leak down done so you know which side it is on.
Don't forget if its a head gasket blown, you will need to mill the head, maybe 5 thou just to clean it up. Might have to do both sides, but pull all the rockers off, then do the LD test.
Will-do, thanks.
When I turn my A/C on, both fans come on "high" and stay on the entire time. I had a thread about this and everyone tried to help me figure it out, I tried everything that this site could dish out. I just can't figure it out. The only way I can use my A/C in the middle of the summer down here is if I'm cruising on the highway steadily, then it will stay cool enough not to have any detonation.
Do you still have the factory fan settings, and what degree thermostat is in it? Sounds like your tuning is at max timing for a givin low temp, and when the motor becomes heated, it detonates. The timing may need to be backed off some, or a 160* t-stat installed and fans programmed accordinglly, if not already done.
The only thing I haven't tried is installing a brand new condensor. I really don't know what else to try.
As far as the fans go. I've gone for a ride, let it get hot and every minute or so I would pull over to check if the fans were on, and they run on high the entire time. It still gets hot.
I would pull the spark plugs out of the motor and see if one looks different than the others. Also on the cooling issue I had a mustang that had ford racing underdrive pulleys and had similar problems, went back to stock pulleys cooling issue went away. I guess it could also be a volume issue with the radiator if it is a stock radiator.
It was rebuilt, installed and now I have this problem.
So it wasn't there before and everything is the same pulley-wise and other-wise.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#32
The overheating could be several things: Poor or no coolant, Improper coolant level/mix, bad fan, missing fan shroud, partially clogged radiator (have flushed), bad water pump (possibly a broken impeller. check last) . In the A/C it could have a bunch of junk between the condenser and radiator. Maybe get a flush? But I still bet it has to do with the gasket, did you check the rad cap to see if the level moves if you give it some revs in neutral?
#33
All those other things you listed were checked by me, the dealer and a radiator shop. Everything looks good. I don't know about the impeller though, but with the A/C off the engine runs very very cool even in traffic on a very hot day. Its just as soon as that A/C is turned on, all hell breaks loose, and fast too.
I;m going to flush the radiator tomorrow and fix that damn pulley that flew off tonight.
Thanks. Did you get my PM.
#34
If the engine is at operating temp with the t-stat open, shouldn't it also shoot up and out?
I don't understand the pulsating thing?
When should I do this...cold or hot?
#36
The pulsating means the cylinder compression is getting into the coolant, pretty much telling us its a gasket issue... Thats where your coolant is going.
Can casual driving damage the head or block. I can't get this thing to Mike Norris just yet.
#37
I wouldn't drive it unless totally neccesary...If the gasket gets worse and the motor takes a big gulp of coolant, you could hydraulic the motor.
Wade is thinking the overheating could be an airlock because your 2 sensors are reading different temps...
#39
Lyle, clear out your inbox. thanks
Whats the best way to flush my coolant system? I went to the auto parts store and couldn't find any type of flush fluid or flush kit.
