Stage 1 LS6 heads worth it??
Old Jan 5, 2006 | 09:36 PM
2scoot's Avatar
Both Patriot and Livernois have a great deal on LS6 heads right now. Talk about a buyers market.
I'm building a LS6 right now and I'm fortunate enough to live close to Livernois, so I dropped my heads off to them the other day. These 243's will flow good numbers. I'm having the head fully CNC'd and milled then reassebled with TSP double springs and Ti retainers. My intention is to keep air velocity as high as possible within the head. I've taled with all of these guys and you cant go wrong with any of them, just great customer service and the knowledge to go along with it. So get out the credit card and do it!
Old Jan 5, 2006 | 10:37 PM
dug's Avatar
dug
Originally Posted by silverTA2002
Stock bottom end, 10 bolt... 135mph trap speed.
I wouldn't bother, seems like you're "pushing your luck" as it is.
I admit to not knowing too much about nitrous, but wouldn't the added compression from the LS6 heads be a little more dangerous with that big of a shot of nitrous?
I read that 243 heads can run less spark timing than 241 heads and still make the power. That should decrease chances of detonation.
9 second car with stock 10bolt and trans is amazn
What exhaust are you running? THe edelbrock stepped headers with dual 3.5" cutouts should help add some noticabe power.
Old Jan 6, 2006 | 12:09 AM
PREDATOR-Z's Avatar
Ammazing is right. How the heck did you get to a 2750 lbs race weight??
Old Jan 6, 2006 | 06:26 AM
GM Muscle's Avatar
Originally Posted by dug
What exhaust are you running? The edelbrock stepped headers with dual 3.5" cutouts should help add some noticabe power.
I'm running Jet Hots with 18" extensions at the track. I run 2.5" duals on the street but those are going in the trash for something else. The 10 bolt does have axles and a girdle.
The 2750lbs for next season shouldn't be too hard (note that's the cars weight with a 1/4 tank, not race weight). The car was 2850 last season. I have done all the usual stuff plus some more extreme stuff. Like cutting 14lbs of wiring out of the stock harness, taking out any unused interior brackets, cut off the front of the frame rails, no power steering, and the list continues. This season I'm addind a pin on hood, K-member, plexi side windows, light weight carpet, 10lbs Kirkey seats, and some other stuff.
Old Jan 8, 2006 | 04:50 PM
Speedpup's Avatar
Originally Posted by REDWS6ROCKET
i'm in the same boat as well, i have been looking at the ls6 heads for a while too.
nice Camaro
