Rocker-Arm bolts - It wont come off
I needed to pull my rocker arms off to check my pushrods, and they are on there really good, i know they are torqued right because i've pulled them once and put lock-tite on them and torqued them to 22ft/lbs. I think that the lock-tite just is holding them really well, but now i need to get them off and i dont know how, does anybody have any ideas or suggestions? I was thinking cleaning out the inside of the head real well and using a torch to loosen the lock-tite, but that seems like it would end up badly.
GM makes those bolts as well as the crank and head bolts with the flat washers as part of the bolt head. You put the locktite on the face of the flat washer NOT on the threads themselves. Use a 6 point 3/8ths drive socket and a breaker bar. You can even extend that with a short piece of hollow tubing or pipe. Push down on the breaker bar at the socket and give the breaker bar a HARD, QUICK snap to break the locktite. After that you can turn the bolts out with your fingers.
It was blue, i used a 12 point, but it started to turn so i stopped, i also broke the adapter that goes from the medium size socket to the smaller, i didnt try any more after that, i dont think i'll be using locktite on the new heads, i just need these rocker arms. I'll go buy a 6 point and see how that goes, i just wanted to make sure they wouldnt break
