Motor Swap now car wont start
Old 01-07-2006, 02:21 PM
SSLS1's Avatar
Default Motor Swap now car wont start
well i just installed my new motor and now it wont start, when i turn the key on all the accessories power up and evrything but when i turn the key i got nothing, no clicking as if it was a dead battery, so i touched a screwdriver across the starter and it tryed to start the car, so where else do i look? i already checked the wires to the starter, help
Old 01-07-2006, 06:09 PM
XtremeDime's Avatar
fuel.
Old 01-07-2006, 06:13 PM
Mike94ZLT1's Avatar
Originally Posted by XtremeDime
fuel.
Are you getting a good ground? If so, pull the starter and take it to autozone and have them test it. Do you hear a clicking when you turn the key like the bendix is popping out? If theres no clicking, do you hear it spinning inside the case?
Old 01-07-2006, 08:11 PM
XtremeDime's Avatar
if had the same prob and my fuel pump was toast
Old 01-07-2006, 08:32 PM
1BADAIR's Avatar
He meant it wont crank.
Auto? try moving the shifter through the gears while holding the key.
Old 01-07-2006, 08:35 PM
93LS1RX7's Avatar
It would still crank if the fuel pump was bad. He said it wont even crank over when using the key so it aint a fuel pump.
Old 01-07-2006, 08:41 PM
jrp
SN95 Director
jrp's Avatar
double check all your sensor connectors. i forgot to plug in the crank position when i swapped my motor, when i found the probem and plugged it in started up fist try.
Old 01-07-2006, 08:49 PM
1BADAIR's Avatar
check and make sure you hooked the s-terminal up to the starter.
if so check for power while someone hold it in the crank position
Old 01-07-2006, 08:54 PM
1BADAIR's Avatar
theft will make it not crank too
Old 01-07-2006, 11:08 PM
SSU's Drunk Typing Whore
Lithium's Avatar
PCM...make sure those bolts are down good. That was my problem and solution
