$hitty oiil press..
Old Jan 9, 2006 | 07:49 PM
D'scamaro's Avatar
Default $hitty oiil press..
i did a search and found some stuff, but none with the same prob.
i just put in my 408 longblock with a 242 249 cam and ported oil pump, well it looked portedanyways, and all i had to do when i got my motor was put on the pick-up tube and o-ring and thats it, and i made damn sure that the o-ring was on right, and the screen was closed... and when i start it up cold i only have 20 psi and when its hot i have 0 psi!!! so what could it be??
could the pushrods be the wrong length, could that cause low oil press or what else?? i cant think of anything else... let me know PLEASE thanks
Old Jan 9, 2006 | 07:57 PM
ss rally red's Avatar
I helped a freind of mine install a FMS 408 stroker in his car and after the install we could not get it to start! Come to find that with the base circle of the cam that was installed we had to have pushrods that were .25 shorter in lenght(basically no compression). Once we did that it fired up right away,now I know this is not the same problem you are having but my point is with a custom motor it could be anything causing the problem but it could be something very minor,check it all and good luck to you
Old Jan 9, 2006 | 08:01 PM
D'scamaro's Avatar
thanks man what all do you need to find out the pushrod length, i know they put 7.4's back in there, but i have the lq9 heads 242\249 cam thanks
Old Jan 9, 2006 | 08:22 PM
Steve Bryant's Avatar
LS1 Tech Veteran
There are three plugs and an O ring seal that close the oil journal on the driver's side of the block. Do you know if all were installed?
Best of Luck. Don't start this up any more until you figure out the problem.
Steve
Old Jan 9, 2006 | 08:33 PM
LS198Z28's Avatar
who built the motor? Yoy might also check that the pickup tube is not bent down to where it is hitting the pan. there should be a little gap between it and the pan. also what oil are you running?
Old Jan 9, 2006 | 09:01 PM
dlandsvZ28's Avatar
There's another thread nearly identical to yours, same problem. And another in another forum.
There is a plug in the back of the block that either fell out or was never reinstalled by the builder.
You would think by now that the builders would post a sheet attached to the block with an extra plug attached to make sure this plug is there and if not then install the extra.
His post when he found the problem.
Does anyone know what the plastic plug in the rear of the block looks like? I am not sure what I am looking for. Anyone got any pics? There are three holes that I see on the back of the block. 2 on the top and one on the left side.I dont see any plastic plugs anywhere, and if it missing the plug, id say it is the hole on the left side.??? Help someone!
Old Jan 11, 2006 | 06:45 PM
D'scamaro's Avatar
thanks guys
can yall point me in the direction of the oil sending unit please??? thanks a ton again guys!!!
Old Jan 11, 2006 | 06:58 PM
LS1 Tech Veteran
The oil sending unit is on top of the block, behind the valley cover at the rear of the engine. It is a tall, tubular device that screws into the block and it has a couple of wires coming out of it.
Steve
Old Jan 13, 2006 | 11:59 AM
D'scamaro's Avatar
thanks man, i know i bought a new one for my last motor, which i used for about 7 months and it was fine then.... but thanks for that info,
im pulling my tranny out and going to see if those plastic plugs are in there...
the plastic plugs are, two behind the rear cover and one near the oil filter right??
it might have been an oversight of mine since the block was black and all, thanks
Old Jan 13, 2006 | 04:51 PM
LS1 Tech Veteran
The front plug is behind the timing cover. The rear is a plastic plug installed behind the rear cover. There are also two side plugs which I assume are installed because if they weren't, you would have oil coming out of the left side of the block. If I get a chance tomorrow, I'll go out and take some pictures of the 6.0 L block that I bought to build my 408 stroker that I'm planning. Then I'll post them.
Steve
Old Jan 14, 2006 | 06:11 PM
LS1 Tech Veteran
Here are some pictures that I took this afternoon for you. Note: I turned the block upside down to make it easier to take the pictures, then I inverted the pictures when I was editing them.
Steve
Attached Thumbnails $hitty oiil press..-front-oil-passages-copy.jpg   $hitty oiil press..-rear-oil-passages-copy.jpg   $hitty oiil press..-left-exterior-block-copy.jpg
Old Jan 15, 2006 | 01:55 PM
LS1 Tech Veteran
D'scamaro, are you having any luck with the oil pressure issue?
Steve
Old Jan 16, 2006 | 06:20 PM
D'scamaro's Avatar
im taking of the flywheel but one of the bolts stripped... now i dont know what to do for that, i guess drill a hole in the bolt with a bit right???
thanks for the pics steve
Old Jan 16, 2006 | 07:20 PM
LS1 Tech Veteran
Right, center punch the bolt and drill it out progressively, one or two sizes at a time. Take your time with things. I know that you have to be frustrated with things. Been there, done that, more than a few times.
Here's a good article on rebuilding the Gen III engines with some pictures and commentary that will help http://www.babcox.com/editorial/ar/eb040538.htm.
All my best,
Steve
Old Feb 1, 2006 | 06:12 PM
D'scamaro's Avatar
i thought about this today, abot welding a nut to the bolt that is stripped, welded real good and taking it off... i thought that was a good idea, what about y'all??
Old Feb 1, 2006 | 08:20 PM
LS1 Tech Veteran
Are you saying that the threads stripped or are you saying that you rounded the corners off the bolt head?
Steve
Old Feb 1, 2006 | 10:59 PM
SUX2BU's Avatar
cut a corner off the bolt with a cutting wheel and then take a chisel to it to spin it loose. thats how i take out stubborn stripped bolts.
Old Feb 2, 2006 | 05:37 AM
Slowhawk's Avatar
LS1Tech Sponsor
I would say the rear plug is not there.Pretty common to miss it if your not use to building these.
I've welded nut's to the flywheel bolt a few times.
Old Feb 3, 2006 | 07:01 PM
D'scamaro's Avatar
the bolt is rounded off, should i get one the same size and weld where they meet or a bigger nut that fits around the rounded off bolt and weld it from the inside?? thanks for the info guys, its really helped me
Old Feb 3, 2006 | 07:47 PM
LS1 Tech Veteran
Probably either way would work. However, have you tried vice grips? Also, if the corners of the flats are rounded off and you can center punch it and drill it out progressively (just through the thickness of the head or about 1/4"), when the diameter of the hole is about 1/4" or slightly bigger, you can just twist the head off with some vice grips. Then, take the flywheel/flexplate off and back out the remainder of the bolt with some vice grips.
BTW, stripping a bolt or nut means that you damage the threads. Hopefully you haven't done that in addition to rounding off the bolt head. You are probably fine on the threads.
Steve
