Rate my headflow numbers.
Old Jan 10, 2006 | 10:12 PM
popinsmoke's Avatar
Default Rate my headflow numbers.
http://www.we-todd-did-racing.com/we...ZkMzF5NTQx.jpg
Looking to run a F14 cam, TTS longtubes and matching ORY , TSP Rumbler catback and a dyno tune.
I am looking for 450rwhp think I can make with this combo?
Old Jan 10, 2006 | 10:28 PM
destroyerSS's Avatar
i do not think you'll get 450rwhp with these heads
Old Jan 10, 2006 | 10:32 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Those are some good low and mid numbers.
Looks like stage 1 5.7L head #'s.
Old Jan 10, 2006 | 10:34 PM
!LS1 11 Second Club
300+ cfm @ .600 heads may give you about 10 more peak hp, but you're at least gonna make great power under the curve with the heads flown in the graph.
Old Jan 10, 2006 | 10:45 PM
JZ'sTA's Avatar
Heads look pretty good I would have taken the flow number to .600 instead of .550 to see what they do up top.
They might go turbulant and they might continue to flow. Who knows????
I am guessing if those heads are milled or have larger valves flycuting might be a must with the F14.
Make sure you check it during the install.
Old Jan 10, 2006 | 10:57 PM
roughneck427's Avatar
should get you exhaust flow a little higher to get your percentage up looks like they did great on the intake but didnt do alot on the exhaust these #'s are on my LT1 heads not hating at all wish i had a LSX series motor
LIFT: INTAKE: EXHAUST: PERCENT:
.100 66 59 89.3
.200 138 115 83.3
.300 182 151 82.9
.400 224 172 76.7
.500 255 186 73.0
.550 264 195 73.8
.600 270 199 73.7
Old Jan 10, 2006 | 11:49 PM
!LS1 11 Second Club
TEA
Stock valves, exhaust flown w/pipe
.100 73/--
.200 144/---
.300 109/149
.400 252/189
.500 283/219
.550 296/232
.600 294/245
__________________
Old Jan 11, 2006 | 12:32 AM
popinsmoke's Avatar
Thanks for the replies so far. what do you think of my cam choice do you the the f14 is a good choice?
I am looking for a good broad powerband from the engine rather then peak narrow band power.
I am also going to run a 100hp dry shot as well any concerns there with this combo?
I should also add that the car is a 02 Z28 convertible with a M6.
Thanks allot for your input.
Old Jan 11, 2006 | 12:42 AM
!LS1 11 Second Club
What heads are they?
F11 would give a broad power band.
Old Jan 11, 2006 | 01:51 AM
popinsmoke's Avatar
Heads are stage 1 ported 243 castings from Pro-Flo inc.
Assembled with stock stock valves and patriot gold springs.
Old Jan 11, 2006 | 02:03 AM
!LS1 11 Second Club
Here's an F11 GMPP CNC LS6 heads thread.
https://ls1tech.com/forums/showthrea...ght=futral+f11
Old Jan 11, 2006 | 08:25 AM
Patrick G's Avatar
LS1 Tech Administrator
Exhaust numbers look weak in comparison to the strong intake numbers. I'd probably run a cam with quite a bit more duration on the exhaust vs. intake. IE a G5X-3 would be a better choice than an F-13.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 11, 2006 | 04:50 PM
Bigrob339's Avatar
Exhaust numbers are terrible, better have some more duration on the exhaust side of the cam. Intake could be better but it will work.
Old Jan 11, 2006 | 06:33 PM
popinsmoke's Avatar
What can I do to bring the exhaust numbers up?
How much power am leaving on the table with those exhaust numbers?
Old Jan 11, 2006 | 06:56 PM
!LS1 11 Second Club
The exhaust #'s look comparable to MTI LS6 2E's. What's all the fuss?
http://www.motorsporttech.com/fbody_engine01.asp
Is this a flown with pipe/ no pipe thing? I think for a Stage 1 port, they're not bad at all.
Old Jan 11, 2006 | 09:52 PM
popinsmoke's Avatar
Hmmm my heads do seem to stack up. time for me to do a search and see If I can find some dyno results from those heads and some different cams.
Old Jan 13, 2006 | 10:50 AM
383ss's Avatar
with a cam that lifts to .598??
Old Jan 13, 2006 | 02:46 PM
!LS1 11 Second Club
The heads are still gonna make power nevertheless. More is always there of course.
If it's in his best interest to upgrade further is something he needs to decide for himself.
Old Jan 15, 2006 | 10:36 PM
popinsmoke's Avatar
I still have not decided what cam I am going run
However I have decided to run a cam with more exhaust duration if for no other reason than I am planing on runing a 100hp dry shot and nitrous seems to enjoy the extra exhaust duration.
Anyone know a ballpark lift limit on non milled LS6 heads before I have to start thinking about flycutting?
Old Jan 16, 2006 | 02:19 AM
AINT SKEERED's Avatar
I am running heads that dont flow what yours are flowing . I made 425/410 with the f13 through a 12 bolt,33 spline axles , 31/2" steele drive shaft on 17 " rims and 4.30 gears . My heads are very close to what a stock set of ls6 heads flow.
I have a thread in the Dyno section about Edelbrock headers with dyno graphs if you want to see how good the power band on a f13 looks.
F14 would not be a bad choice either though. Or get Allan Futral to cut you a custom f14 that he does for guys that want a little more exh. for nos. 232/236 .598/.598 114 lsa+4
