4 Cam choices for 408 "Which one"?
Old Jan 11, 2006 | 01:43 AM
marine02ss's Avatar
Default 4 Cam choices for 408 "Which one"?
Friday will be the day I order cam for my 408.Its ready to go,just need cam.I already installed afr205s,fast 90/90,HLT,TNT 150. I want to drop it in by next thursday,so I need to order as soon as possible.My car is a A4 with 3500.I narrow it down to FOUR "Magic stick 237/242,Texas Giant,CC 244/248,G5X4.
What will the diffrence be if I get the custom grind on a 110 vs 114,115.Will power differ,idle or how soon the power comes in.I dont want to spin past 6500rpm or 6800-7000 on the juice.What will it be?,any experience users chime in,ThANKS GUYS!!!!!! REMEMBER DAILY DRIVER,OCCASIONALY OUT OF TOWN
Old Jan 11, 2006 | 01:54 AM
Y2kforgedSS's Avatar
How much spray will you be using? A 110 lsa is going to have a much rougher idle and hp will peak out faster than say a 114 lsa or 115 lsa. I would go with the MS3 237/242 .603 .609 with a 113lsa its got a mean idle and loves spray. I have the MS3 and i usually shift at about 6700rpms with a 150 shot.
Old Jan 11, 2006 | 06:39 AM
s346k's Avatar
i would go much larger than the cams you've mentioned, as the 408 cid will eat up a small cam. try the texas speed giant...on their website. something similar in size to that. on a 114 lsa...
Old Jan 11, 2006 | 07:07 AM
PREDATOR-Z's Avatar
Minimum 244+ durations
Old Jan 11, 2006 | 07:41 AM
marine02ss's Avatar
Texas giant is 248/254 isnt that, tad to big for a 408 daily driver?It will probably make good power,but what about the lowend, will it suffer?
Old Jan 11, 2006 | 08:57 AM
PREDATOR-Z's Avatar
Big cubes=loads of torque, LOL you would have problems keeping from spinning at every take off. Need big meats and good weight transfer to minimise.
Old Jan 11, 2006 | 10:41 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
The Texas Giant 248/254 camshaft should work really well in that 408. We've installed it many times & I've always been really happy with how it made power & daily drives. I have a dyno sheet of a ls2 402 with the texas giant in the 408 section of our new site 520rwhp with a ls6 intake & 11:1 compression!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jan 11, 2006 | 10:45 AM
Phil99vette's Avatar
7 Second Club
I like the 248/254 on a 110 + 2.
Phil
Old Jan 11, 2006 | 10:46 AM
7 Second Club
Are you saying that a 114 will make more power on the top or have a broader power band?
Phil
Old Jan 11, 2006 | 11:08 AM
gtovan's Avatar
Since you have an A4 w/ a 3500 stall and mainly a daily driver, I would go with the 244/248 cam you listed and look at 110 ICL/ 113 LSA.
Old Jan 11, 2006 | 11:12 AM
PREDATOR-Z's Avatar
Bigger strokers do not require higher stall to benefit from bigger cams. Too much trq down low, so low band can be used early.
Old Jan 11, 2006 | 12:59 PM
marine02ss's Avatar
Anybody have clips of the TGiant.or similiar suggested cams,or dyno graghs
Old Jan 12, 2006 | 11:56 AM
marine02ss's Avatar
Well guys I called around yesterday for some advice and heres the advice I got
MTI -R1 232/236 114
TSP - 244/248 114
Speed Inc 232/232 114+2
Comp cams 228/230 114 .595/.573
LG G5X2 232/240 .595/.609 114
What do you all think,which will get me close to 500rwhp and have good drivability
Old Jan 12, 2006 | 01:23 PM
NOZR1's Avatar
I went with the HPE Big E cam.
Old Jan 12, 2006 | 01:31 PM
SSilverSSurfer's Avatar
that cam rocks...it was deisgned by E llie...i would do a 26x/26x duration cause im crazy like that
Old Jan 12, 2006 | 01:53 PM
7 Second Club
I would do a 6 degree split, call Jason @ TSP and tell him to get you a 244/250 XER 111 + 2. She will make the power.
Phil
Old Jan 12, 2006 | 02:48 PM
Elite_Hot_Rod's Avatar
I've got a 244/248 in my 408 and I'd go bigger now for sure. 260+ duration is probably what a 408 really needs.
Old Jan 12, 2006 | 04:13 PM
beardWS6's Avatar
I put a 244 248 612 615 113lsa in my 408 to go with the spray. I wanted mine to drive smooth for the wife and still have some power. Remember we are a A4. I went really big in my 346, loved the power. But driving daily sucked. Most of my friends didn`t mind it, but after you drive it all the time with kids in the car I didn`t like the issues. All I did to make up the little power I might loose is bump the spray up. I`m going with a 200 shot. I`m also getting ET 245 heads. They are really going to make some power! I have all the bolt-ons etc in my sig going with it. Should make all the power I need!
Old Jan 12, 2006 | 06:52 PM
marine02ss's Avatar
What will happen if I get the same cam 244/248 but at a 115lsa?I just listened to one and it sounds mean
Old Jan 12, 2006 | 07:01 PM
SMDLS1's Avatar
Here you go https://ls1tech.com/forums/showthrea...&highlight=402
