Which head gasket?
Old Jan 12, 2006 | 10:40 AM
scarbrow's Avatar
Default Which head gasket?
12589226 GM Multi-Layer Steel LS1/LS6 Cylinder Head Gasket
Or
12558809 GM LS1 Cylinder Head gasket, graphite
had to pull my heads to change a lifter, which head gasket should i get to go back on?
Old Jan 12, 2006 | 10:46 AM
scarbrow's Avatar
Originally Posted by HASTINGSRJ
What year is your car?? A good rule of thumb is to stay with the same year head gaskets as your heads are (if they are different) Me personally I went back with the stock graphite ones. Go with what you know I guess....
sorry, it is an 01
HASTINGSRJ's Avatar
Old Jan 12, 2006 | 10:49 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I did the multi layered ones and could not be happier! I think it will just make it easier next time I pull the heads off to scrape the block and make sure I got all the little scrap piece cleaned up.
HASTINGSRJ's Avatar
I would say just go back with stock ones....Its all a matter of opinion, which ones you prefer....
scarbrow's Avatar
are the stock ones the graphite or the steel?
Old Jan 12, 2006 | 10:50 AM
HASTINGSRJ's Avatar
I definatly agree with you on that one. Scraping the block is a PITA!!!! but a green scratch pad makes it easy, but still a pain.
Old Jan 12, 2006 | 10:57 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Stockers can be either. I think most "original stockers" are graphite. As I found out.
Old Jan 12, 2006 | 10:59 AM
scarbrow's Avatar
i think mine were graphite, since they had all the little silver flakes going everywhere when i was removing them.
thanks for the help
Old Jan 12, 2006 | 11:03 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
bingo. Yeah I would go with the top GM choice that you listed. that flake crap sucks!
Old Jan 12, 2006 | 11:08 AM
HASTINGSRJ's Avatar
yeah, those graphite ones are a pain, especially after you scrape the block, then you have to use a shop vac to clean out the water jackets and bolt holes etc...what a pain, but the price you gotta pay for HP
Old Jan 12, 2006 | 11:12 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Old Jan 12, 2006 | 11:23 AM
HASTINGSRJ's Avatar
Old Jan 13, 2006 | 01:29 PM
speedybreesy's Avatar
Im on a ranch!
i would have to agree with orangeapeel!!
