cometic gaskets leaking oil?
Old Jan 12, 2006 | 04:15 PM
BLK02SS's Avatar
Default cometic gaskets leaking oil?
I have a 408 with cometic gaskets and one is leaking oil, not water out the back of the passenger side head. any ideas I searched the forums with no luck. Please help.
chuck
Old Jan 12, 2006 | 05:00 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Might be a blown gasket. How many mile you have on them?
Old Jan 13, 2006 | 09:03 AM
BLK02SS's Avatar
i figure around 5,000 or so. car does not skip it has leaked since it has been on there i was just now able to pinpoint where it was coming from.
Old Jan 13, 2006 | 09:08 AM
777's Avatar
777
You sure it's not the valvecover? I'm having a hard time seeing how a head gasket could leak oil. Also how's the oil pressure sending unit. If broken it could leak as well. Just a few options.
Old Jan 13, 2006 | 09:16 AM
BLK02SS's Avatar
it's not the valve cover or sender that was one of the first things i checked. i was also doubtful about the head leaking oil but that is where i think it is coming from. washed it down with carb cleaner and let it idle in the air and you can see a slow trickle coming from the side of the block between the head and block near the last head bolt. is it possible it could be coming up the heat bolt? i was told they were blind holes and only needed moly lube for torqueing purposes.
Old Jan 13, 2006 | 09:49 AM
777's Avatar
777
I'm not sure, but there is no oil passing through the head gasket, only coolant. So how could oil be coming out of there? This is strange. The only thing I can think of is some sort of crank in the head.
Old Jan 13, 2006 | 09:52 AM
BLK02SS's Avatar
i know there is oil returing in drain holes but nothing under pressure. it is not coming out under pressure just a slow trickle not spraying.
Old Jan 13, 2006 | 01:48 PM
vettenuts's Avatar
Drain holes are up towards the intake. Where you describe your leak, not sure what the cause could be
Old Jan 13, 2006 | 01:53 PM
Quickin's Avatar
crack in the head
Old Mar 6, 2006 | 11:58 PM
JoeyGC5's Avatar
im under someone elses name,but are you running arp head studs ? i know they have a common problem with sometimes leaking coolant on sbc.could be the same problem with your but oil .just a thought,sorry if it dont help.
