Gasket thickness
Old Jan 13, 2006 | 02:13 PM
BOTTLE ROCKET's Avatar
Default Gasket thickness
Does anyone know the compressed thickness of the MLS 6.0 gasket?
Old Jan 13, 2006 | 04:44 PM
vettenuts's Avatar
I have seen a couple of different numbers myself so I am interested in this answer as well. Are these for your Dart heads?
Old Jan 13, 2006 | 05:28 PM
That's why I'm asking; I've seen 3 different thicknesses stated, and my chevy dealer "has no idea"!
VN
Yes this is for the Darts. They said to go with a 6.0 so I'm looking at some options. (I like the MLS)
Looks like we're running into some of the same questions on these heads. Let me know when you hear some #s. I am still impressed with the way these heads look. I think they're going to perform really well!
Old Jan 13, 2006 | 06:16 PM
ROCNDAV's Avatar
Nope. ME three.
I bought a graphite Felpro gasket to see the difference between that and my Cometic .040 and the graphite one gave me a squish difference of .014", so the graphite is .054"
I think the mls is .051" but not certain.
Old Jan 13, 2006 | 06:38 PM
vettenuts's Avatar
Do you know the part number of the MLS? I had e-mailed Gunnar at Patriot because I know they distribute this gasket with their heads. Here was his reply, but I am not sure if it is the MLS gasket.
4.00" bore, .055" compressed, 12569365.
Thank you,
Gunnar Bowlin
Patriot Performance
888-462-8276
www.Patriot-Performance.com
Old Jan 14, 2006 | 06:34 AM
A part # I got from here on the forum was a 12589227 fo rthe 6.0. I'm not 100% sure if that's correct. My Chevy dealer here in town is kinda out of it
Old Jan 14, 2006 | 07:13 AM
vettenuts's Avatar
From what I understand, there are two versions of this gaskt an MLS one and a graphite one. I haven't figured out which is which though
Old Jan 14, 2006 | 09:57 AM
SideStep's Avatar
Old Jan 19, 2006 | 04:08 PM
vettenuts's Avatar
I am going to TTT in hopes someone has the part number for the 6.0 GM MLS gasket.
Old Feb 10, 2006 | 09:09 PM
Steve Bryant's Avatar
LS1 Tech Veteran
According to a couple of sponsor web sites, the 6.0 MLS gasket P/N is 12589227. I'd like to know the compressed thickness and inside diameter myself. I'm running a pair on my truck now and I should have checked them with my calipers for diameter at least before I installed them last spring. Of course, compressed height is much more difficult to measure with any accuracy.
Steve
Steve
Old Apr 18, 2006 | 01:41 AM
LS1 Tech Veteran
Steve
Steve
TTT
Just checking again, does anyone have this information?
Thanks,
Steve
Old Apr 18, 2006 | 08:34 AM
Gunnar@Patriot's Avatar
Thank you,
Gunnar Bowlin
Patriot Performance
888-462-8276
This is the MLS head gasket we did send with our heads. It is .055" compressed.
Old Nov 12, 2007 | 11:53 PM
2MuchRiceMakesMeSick's Avatar
TTT
Thanks,
Steve
Search works....
did you ever find the compressed thickness of 12589227's?
Old Aug 24, 2008 | 08:25 PM
Studytime's Avatar
...and what is the gasket bore for this one?
Old Aug 29, 2008 | 09:24 AM
ss1's Avatar
ss1
Supposed to be 4.039" bore, but if you look at Summit they list it as 4.020".
Old Aug 29, 2008 | 11:57 AM
GIGAPUNK's Avatar
cometics thicknesses https://ls1tech.com/forums/generation-iii-internal-engine/977927-mls-head-gasket-thickness-vs-strength.html
Old Feb 14, 2010 | 10:17 AM
Friday13th's Avatar
"Part# 12589227
LS2 / L76 Cylinder Head Gasket. Single unit, required two per engine. .051"" thick, 4.02"" max bore. Standard LS head bolt pattern."
