View Poll Results: Should i change oil pump with cam swap?
Voters: 54. You may not vote on this poll
Change oil pump with cam swap? poll
That's what she said...
Originally Posted by Dan_the_C5_Man
You can also add a small shim under the spring to bump the pressure if desired.
I made a pretty nice post in this thread with what all is involved in shimming. I only discovered it a few days before my camswap and my car has outstanding oilpressure.
https://ls1tech.com/forums/generation-iii-internal-engine/433403-oil-pump-mods.html
