How much can I mill my 5.3L heads?
A friend of mine runs a machine shop and he's going to redo my heads. I have some 5.3L heads, we are going to port them, size them for bigger valves, 3-angle them, and mill them down.
This car isn't a daily driver, I maybe drive it once or twice a week if the weather is nice. I'd like to run pump gas, so I want to be able to run 93 octane with no problems.
What would you guys suggest? I have a Futral F5 cam waiting to go in it as well.
Guess it would help if I put what valves/cam I have.
2.00/1.55 valves are going in the heads.
Cam is a Futral F5 cam - 224/228 588/576 114cl
I'm looking for a good compression boost, around 10.5:1 hopefully.
Anyone have any good milling/head gasket thickness recommendations?
i have the prc stage 2.5 5.3L heads and mine are milled .030. it has 2.04 and 1.6 valves i believe i run the ms3 cam. im at 11 to 1 compression but i have forged bottom end with mahle pistons with valve reliefs.
So you guys think going .030 on them and using the stock head gasket thickness, I'd be ok with the p/v clearance? Or will this be pushing the limits of that and pump gas?
