ET 245's are finally here!!(Pics inside..56k beware)
Well.....It has been a long wait. After almost 6 months my heads are here. Obvioulsy I got in on the ET deal just before stuff hit the fan with their suppliers/hurricanes/foundry issues etc. I can't thank EDC enough for staying in touch with Cary to make sure I'd have the right setup for my new cam.
The heads are ET 245cc 11* valve angle heads. I got them with a 62cc chamber and 2.08/1.60 valves. I also (with the help of Ed) got Cary to do some searching for the "right valve spring" for my custom cam. With lift up in the .660 area I didn't want to leave anything to chance. What we ended up with are valve springs from PSI that are good to over .700" of lift and the matching titaniaum retainers. Cary couldn't believe how radical the cam setup is, and said to keep him informed on the results. He really helped out towards the end making up for all the lost time by assisting me in other areas. Truly a class act as frustraiting as the wait was.
According to LME my motor will be ready to ship on Friday. I'm hoping for some awsome results and almost sure I won't be dissapointed. I left the pics slightly large after re-sizing them so you can see the details. Enjoy:
Originally Posted by gtodoug
I have the super 7 light weight retainers as well, and the heads will be flowed on monday so I'll have some flow numbers for you guys.
Dougie
Dougie
Wow those are purdy. I'm hoping Bryan has a chance to throw them on the bench first thing Monday. Here is the rest of my setup for those who are intrested.
LME built:
6.0L iron block blue printed and assembled opened up to 4.03 bore
Callies Racemaster 4.0 crankshaft
6.125 Callies H-beam rods
Wiseco nitrous forged pistons
Compression Ratio setup at 11.89:1
Childs and Albert dura moly rings
Federal Mogal 152M mains
Clevite cb663H rod bearings
Dura bond cam bearings
ARP main studs
ARP head studs
Morel Hyd. Roller lifters
Cometic head gaskets
ET Performance 11* 245cc heads-2.08/1.60 valves-62cc chamber volume
PSI 1225 .700 lift springs & titanium retainer upgrade
FMS 42lb green top injectors b/bd
AFR Velocity ported FAST 90mm intake mainifold
90mm Nick Willaims TB
Jethot coated Kooks 1 7/8 headers w/ no cats
Custom EDC cam(256/260 .660/.643 114LSA)
SLP high flow LS6 oil pump
Corsa exhaust
ASP pulley
Double Roller Timing chain
LME built:
ARP main studs
ARP head studs
Corsa exhaust
ASP pulley
im very interested to see how your setup performs
i have a similar sized cam (just barely less lift) and a lme 408 aiming for 11.7:1 compresison and prolly gonna order the heads when they arent on backorder anymore
Originally Posted by GuitsBoy
Those are really quite stunning. Im going to have trouble walking with this raging hard-on for the rest of the day.
