large cams in stock cubes
Old Jan 23, 2006 | 10:40 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by pushinfreight
which cam is that?
Custom comp grind. right at .600
Old Jan 23, 2006 | 10:41 PM
pushinfreight's Avatar
Is there an optimum valve size for the Trex that you know of?
Old Jan 23, 2006 | 10:42 PM
intake and exhaust for the lift?
Old Jan 23, 2006 | 10:45 PM
SMOKIN01TA's Avatar
um, on stock heads you better stay with the stock valves or youll be in big trouble.
now, the cam in general was designed with stock heads but works very well on aftermarket ones, im goin for 500rwhp wth my h/c package
Old Jan 23, 2006 | 10:49 PM
I have stock LS1 heads that have been ported and milled. The valves are stock size, I just wanted to know if going to a bigger valve size would be bennificial since the motor was going to be apart. If I hit 470 I will be happy. I just want to see a bit more tq than the 402 with the current setup. The spray will make up the rest so I can keep up with locals here in Tampa.
Old Jan 23, 2006 | 10:51 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, how much were they milled? You might be kissing pistons with the T-Rex.
Old Jan 23, 2006 | 10:55 PM
new pistons will be cut to account for the lift of the Trex. The compression right now is 11.7:1 but I have developed a blow by issue so the motor is coming apart and forged interals are going in.
Old Jan 24, 2006 | 05:08 PM
any one else running 236/236 or larger?
Old Jan 24, 2006 | 05:45 PM
Kraest's Avatar
I'm running the F-15 Futral cam on a 112 +2. 236/239 .600/.611 with the stock rockers and PRC duals. No problems at all.
Old Jan 24, 2006 | 05:47 PM
Phil99vette's Avatar
7 Second Club
We're running a 254/260 112 + 2 .650/.650, PSI springs, Jesel Rockers and Lunati Lifters.
Phil
Old Jan 24, 2006 | 05:58 PM
Phil
stock cubes? That is a huge cam!!!!
Old Jan 24, 2006 | 06:49 PM
  #32
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Its a solid roller though.
Old Jan 24, 2006 | 10:53 PM
  #33
Well that explains it. I was trying to figure out how that would work on a without being a solid roller.
