Car has been sitting for 3 months
Old Jan 24, 2006 | 12:17 PM
shudog's Avatar
Default Car has been sitting for 3 months
I'm going to start it this weekend. Definitely changing the oil. Gas tank is full so that shouldn't be a problem. Anything else I should check? I've never let it sit so long with out starting it up.... I've been working out of town alot though...
Old Jan 24, 2006 | 12:43 PM
cyphur's Avatar
Just make sure you don't have a full tank of bad gas.
Old Jan 24, 2006 | 03:26 PM
shudog's Avatar
Gas isn't a big concern, it's only been a couple months, my garage is warm & dry. At most it lost some octane. I was more concerned with anything internal...
Old Jan 24, 2006 | 04:08 PM
Ferocity02's Avatar
Gas usually only takes about 6 weeks before starting to break down into ****. I think it will be fine though personally.
Old Jan 24, 2006 | 04:17 PM
KGSloan's Avatar
personally, i'd pull the fuel pump fuse and disconnect the coil packs. then turn the car over with the starter until you see oil pressure.
i let my car sit for around 3 months when my clutch went out. i was worried about oil pressure and did the above. it took a long time for the pressure to get off of zero.
Old Jan 25, 2006 | 12:05 PM
shudog's Avatar
Intersting point. How long is a long time? About the same as when you change your oil? Because I plan on changing mine before I drive it.
Old Jan 25, 2006 | 04:00 PM
SS1875's Avatar
I had a QA1 shock seal go bad on me while mine was sitting waiting for a motor...maybe check stuff like that as well...you never know.
Old Jan 25, 2006 | 07:33 PM
DanZ28's Avatar
Mine sat in the garage for 18 months and ran fine on the 1/2 tank of gas that was in there, although half of it was 100 octane. engine oil was fine, oil pressure snapped right to 60 on start up, I did change it after warm up. I did pull the coil pack plugs and turn it over for about 20-30 seconds first though. I don't think 3 months is much to worry about IMO, but doesn't hurt to check things out...
Dan
