Removing oil pan...help.
Old 01-25-2006, 06:48 PM
SSU's Drunk Typing Whore
Lithium's Avatar
pretty please? I atleast want to get this pan out today...
Old 01-25-2006, 07:01 PM
Ωmega's Avatar
I would support it just to be safe. Only loosen the bolts as much as you need to in order to get that pan to slide out.
Old 01-25-2006, 08:18 PM
WhiteRhino's Avatar
When I did mine I just undid the drivers side and pulled it down as far as the brake line would let me go.I also jacked the motor as high as it would go then.Then wiggled the pan out.I used the crank snout.I know some say not to,but I've got over 20,000 miles since I've done it with no issues.
Once you do the K-member be prepared to go get your front end aligned.It can mess the alignment way up.I'm not sure I undid all the right bolts but only the brake line was holding it and when I got it back together my alignment was shot.
Edit: I took the bolts all the way out.
Old 01-26-2006, 07:59 AM
King James's Avatar
Use something to support the engine from the top. Some people use a piece of wood across the shock towers with chains bolted into the front of each head. I personally have this to use
Unbolt the engine mounts and support the K-member with a jack. It will probably be easier to take out the A/C compresser and alternater to unbolt the mounts. Take out the 6 bolts and lower the K-member while watching to make sure nothing is going to get pulled out or broke. You will probably have to take the bolt out of the steering shaft also. Once the K-member is lowered you should have plenty of room to work.
Old 01-27-2006, 06:02 PM
Lithium's Avatar
Got all 6 bolts loosened and it will not drop any. I need to stick something in there and pry it loose? correct?
Where is the best spot to stick something in there at?
Old 01-27-2006, 10:15 PM
Lithium's Avatar
bumppp
Old 01-28-2006, 06:30 AM
King James's Avatar
That's weird! Did you unbolt the motor mounts?
Old 01-28-2006, 11:30 AM
Lithium's Avatar
Yeah both motor mount bolts are out and the engine is jacked up.
Old 01-28-2006, 11:38 AM
LS1TECH Sponsor
Steve Burger's Avatar
Unboltthe shocks from the lower A Arm. They may be holding it back.
Old 01-28-2006, 11:50 AM
Ωmega's Avatar
That or the spindle arm.
Old 01-28-2006, 11:52 AM
Lithium's Avatar
I got the passengers side to drop but the drivers side is not.
Old 01-28-2006, 02:19 PM
  #32
Lithium's Avatar
Got the K member lowered - thats done. Got the jack with some wood under the bellhousing jacked up all the way it can go. Now, I seriously only need less then another quarter inch or so for the pan to come out. Any ideas???
Old 01-28-2006, 03:14 PM
  #33
Lithium's Avatar
Sorry for my stupidy on this guys... Unbolting the steering linkage...where and how many bolts? sorry
Old 01-28-2006, 04:21 PM
  #34
Griswold's Avatar
you are still going to replace that oil pump right?
Old 01-28-2006, 04:24 PM
  #35
Lithium's Avatar
Well I will after all this.
I am still at a loss for why the ls6 pump is not working...I took it apart and compared it with the stocker and found nothing wrong or out of place.
Old 01-28-2006, 04:59 PM
  #36
Lithium's Avatar
Now I am starting to get pissed off...
I seriously need Milimeters now...I cant get it to drop any lower. I unbolted two more bolts in an attempt to drop it lower and nothing...
Anyone?
Old 01-28-2006, 05:39 PM
  #37
Lithium's Avatar
I am giving up.
I just unbolted those 4 bolts holding the shock down. Of course nothing. I really dont know what I am doing anymore and nothing seems to be working.
Old 01-28-2006, 06:41 PM
  #38
Lithium's Avatar
annnnnnnybody? please? wish I knew more **** when it comes to this stuff.
Old 01-28-2006, 06:44 PM
  #39
Ωmega's Avatar
So the K-member won't drop anymore at all?? I dunno...maybe check the hard lines for the power steering pump, maybe that's holding it up? I'm not sure, trying to think of what could be keeping it.
Old 01-28-2006, 06:49 PM
  #40
Lithium's Avatar
Yeah man I am lost too. I seriously only need this much more room -------
