Eagle 4.1" crank
Originally Posted by NoGamesLS1
Im looking at an iron block bore .040 With this crank Id be at a 420.46. Anybody see any problems? Also how big of an injector would I need?
Also anyone looking to get rid of a 6.0 block?
I assume you already have a new fuel pump and a clutch if you are an M6. My H/C package made short work of my Z06 and I only got 1 season from a Spec 3.
With the added power, lots of things will break, just a warning.
Rampant
Im going with a ls2 fw and ls7 clutch. I know that I will need a new fuel pump, but havent gotten one yet. Any one that you would recomend? What problems have you had with thing breaking?
Originally Posted by Beast96Z
Guy's, there's no reason to lurk. The crank will fit with no problems. Your mechanic is going to have to clearence the block for a 4" stroke, so no more work is involved when clearencing for a 4.100" stroke. There are lots of guys on here using the 4.125" crank in a stock block w/stock sleeves. If it makes you feel better, I have a 4.185" stroke crank in my motor.
are there any pics on where the clearancing is needed to fit a 4.125" stroke crank? i'm debating on doing a stroker with the wife's block after i remove it.
