BIG question
Old Jan 27, 2006 | 01:53 PM
Haans249's Avatar
Default BIG question
So, I just pulled my intake off to replace my intake port seals....and I found the following!!
Question, is this normal? What could be causing this? Is it something of concern? Its very gummy, and its not in all of the cylinders, just number 3, a little bit in 7. I also looked further down in the port and its almost clean...should I not worry about it? Just wipe it up?
Thanks!
Adrian
Old Jan 27, 2006 | 01:57 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Wow, you sporting an LS6 PVC or catch can? What does the inside of the intake look like?
Ouchburns's Avatar
Is that oil??? There should not be oil in there! Maybe a piston ring is gone?
Redneck Z's Avatar
Yeah it's normal. Just wipe it up. At least you didn't have rat terds like I did lol!
Old Jan 27, 2006 | 01:58 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Lol you had rat **** in your intakes?!
Old Jan 27, 2006 | 01:59 PM
z28C4maro82z's Avatar
I would like to see what htis appears to be. I haven't taken my intake off ever, but have to upgrade to an LS6 at some point. Just want to see what this is, if for whatever reason I take mine off and run into this, I would like to know exactly what it is. Good picture too
Old Jan 27, 2006 | 02:00 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Same here, pulled the intake off to swap it with the LS6 then found rat ****...
Haans249's Avatar
hahaha, thats insane....yea, i've got the LS6 PCV, and its only on that cylinder, I didn't suspect gone ring cause I have no oil burning coming out of my tailpipes. Anyone else before I button it back up?
Thanks!
Old Jan 27, 2006 | 02:10 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Kory, is your car gonna run...ever? That last surgery you put it under must have been when the **** appeared!
LS1thunder's Avatar
Could be a valve oil seal going bad.
Old Jan 27, 2006 | 02:12 PM
Lithium's Avatar
LMAO...yea I just got to drop the k member now then pull the pan. It will be done today hopefully.
Old Jan 27, 2006 | 02:13 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Glad to hear it. Make sure you get all **** and paper towels out before you take it for a spin.
Old Jan 27, 2006 | 02:16 PM
Lithium's Avatar
Hahaha definitely. Hopefully I can swap out the rod bolts to when I am in there.
Old Jan 27, 2006 | 02:47 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Always a good idea. Especially since you are gonna be cranking out the higher RPM's with that magic stick.
