Another double roller ?
Old Jan 28, 2006 | 10:47 PM
ashade98's Avatar
Question Another double roller ?
How much clearance do you guys have between the chain and the oil pump with the spacers? I don't know in thousandths, but I'd say I have about 3/32 or a hair less. Just wanted to make sure before I button her up.
Also, who has modified the oil pickup tube due to the spacers? I installed my new o-ring with lots of oil on it and inside the oil pump seat and didn't fully tighten the pickup tube bolt until the oil pump was torqued down. I did notice that it moved it out a bit, but it seemed to seat nicely. I guess we'll see!
Thanks
Old Jan 29, 2006 | 12:13 AM
ashade98's Avatar
As far as the clearance goes, I'm pretty darn sure I got the crank gear seated all the way. It slid on all the way by hand... pretty tight though. Then I put the old one on anyway and gave it a tap or two very lightly. It was seated.
Old Jan 29, 2006 | 09:48 AM
ashade98's Avatar
Anybody? TTT
Old Jan 29, 2006 | 12:16 PM
ArcticZ28's Avatar
It's not gonna be TOO much clearance. I don't know exactly but if you are absolutely sure the crank gear is seated all the way then I wouldn't worry about it.
Old Jan 29, 2006 | 01:30 PM
ashade98's Avatar
What about modifying your pickup tube???? I didn't, do I need to get back in there??
Old Jan 29, 2006 | 01:37 PM
Lithium's Avatar
SSU's Drunk Typing Whore
What do you mean modify it?
Old Jan 29, 2006 | 02:30 PM
ashade98's Avatar
Check out this earilier tread, you posted in it as well.
https://ls1tech.com/forums/generation-iii-internal-engine/444297-dot-s-lined-up.html
Johnv posts:
"Have you slotted the oil pick-up tube mount (in sump) to allow for the pump spacers moving pump out ? if not tube may not centre in pump correctly and can cause oil pressure problems at start up ."
Maybe he'll chime in?
First time I've heard of such a thing.
Old Jan 29, 2006 | 04:50 PM
ArcticZ28's Avatar
There is no need to modify the pickup tube at all. The spacers are not big enough to cause pickup tube to oil pump mating issues. Just make sure the o-ring is centered on the tube and it's not pinched when you bolt it to the pump. Other than that, u're fine.
 Michael S. Palmer
