The fastest/biggest head/cam combo on stock LS1 and still be reliable?
LS1 Tech Administrator
You'd be absolutely floored how docile my car is to drive. I can lug it down to 800 rpm without protest or surging and it will pull to 6800 like a rotary engine. My car is my daily driver and I take it everywhere. I can even get 30mpgs with the a/c off. SD tuning really helps here.
Reliability comes from a good selection of parts, especially the valve springs. The Comp 921s are awesome and can take lots of miles, even with a high lift cam like mine.
In a nutshell, get as much lift with as little duration as you can and you should wind up with a nice idling motor that makes power everywhere. And don't take the cheap route on valve springs. Lots of details about my combination by clicking my signature.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
The following users liked this post:
Torqueonboost (03-27-2022)
ok thanks a lot! Would i be best off buying a set of heads like darts persay or to get my current heads ported? And is the MS3 in specs to a good all around cam that your suggesting? Thanks alot. Id be very happy with about 425 to rears all motor and a mild 100 dry shot.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
__________________
Yea the only problem when im looking around tho is most guys are on forged motors and what not. I am jsut looking to add heads and valvetrain to my stock LS1 with bolt ons and what not and get some damn good performance, dont want to skimp out.
__________________
Magnus and Jugger are on stock shortblocks. They both run 9.90s. Heads and cam.
As for me, my forged shortblock runs flat-top pistons with same deck height as stock. My valve reliefs actually cost me a bit of compression compared to stock though, but that's the price I pay for reliability on the spray.
__________________
Ok wow, ill def have to check out there set ups, im sure there VERY radical and not very street friendly however. Great numbers however! If i went a nice H/C combo id back it up with a small safe dry shot. nothing rediculous
__________________
Keep in mind, my car makes over 350 rwtq by 3,000 rpm. That's what a lot of torque-biased setups make, but those typically don't make much power above 6000 rpm. Mine does. So basically, I have the street manners of a small cammed setup along with the top-end charge of a big cammed setup. It's like having your cake and eating it too.
__________________
Originally Posted by freakynipples69
I seem to have a big cam according to some people, some cnice heads and I should of reached 440-450rwhp on the stock ls1 block. I think the most rwhp a stock ls1 block will reach with just a big H/C is around that area.
So patrick, you hit 470 rwhp from heads/cam and bolt ons! Thats very impressive. So basically, your set up is the ultimate street killer combo. If so, iwant, haha. Can you give me some more info and maybe some track times? Thanks!
__________________
Originally Posted by 01bird58
One of the sponsors TTPerformance reached 505 rwhp thru a 9" on a stock block H/C LS1. Just pointing out ther are packages out there with higher potential than 450ish.
What heads is he running and who ported them?
Can you give more info on that combo?
#32
Originally Posted by pushinfreight
I had all the bolt-on, cam head work done all at once. With parts and labor you need to expect 4-5k for the work. Now saying that some are going to say that I paid way too much but I went with the following parts:
921 springs
milled and hand ported LS1 heads and were coated, yeilded 11.7:1 comp
arp bolts and head studs
oil pump was cleaned up of all imperfections
long tubes
custom hooker y pipe
custom tune- many hours of tuning at the dyno and street
custom grind cam
Now that being said, does it drive like it was stock? Hell no. The car does not like to go below 1500rpm on the street. The stock rings or one of the pistons gave up the ghost recently but lasted longer than I thought(oil in the inake and smoke about 5k at wot). At the 450+ range on the stock bottom end will go about 10k miles without issues. Anything after that is borrowed time. If you go 430 rwhp on the stock bottom end NA will put you right where you need to be. I would say go with a 23x/23x cam on a 112 and get the best heads you can. Go with head studs and arp bolts all the way around, double roller timing chain, LS6 or LSX78mm intake, ported stock TB, 30lb+ injectors, lt, no cats and custom tune will give you a very fun car that can be daily driven. I would not go below a 3500 stall myself.
921 springs
long tubes
custom grind cam
Sorry to here that another stock piston gave up.
Do you think that the coating may have added to the piston/ring problems?
Who ported your heads?
#33
#34
Hey Patrick, how would you set up do on a stock block as i see your forged? I really like how your set up gives full power range and can run run at low rpms and still pull up top. So for example if i were to throw on the AFR 205 60cc heads and the TRak cam you have along with all the best valvetrain parts and finish bolt ons with headers and intake with 90/90, i would put down close to the same numbers as you minus a few mods and im an a4 but id still get that all around power for ultimate DD as you stated? Thanks!
__________________
#35
__________________
#36
Awesome!
#37
Ok thnaks a lot Patrick. I really like your set up and want to build my bolt ons around it. Think a 3800 stall would be suitable? also with proper tire and such, all motor, what times do you thin k i could achieve full weight approx and would this set up be 100 shot dry friendly?
__________________
#38
I noticed you spoke of reliability because your car is a summer DD, but have you thought about "driveability"? I just pulled my Torquer 2 cam because I couldn't tune out all the kinks 100%. I am by no means an expert tuner, but I worked long and hard trying to get simple things taken care of like idle hunting, and bucking/surging at decel.
Can you live with a 950 rpm idle (you might have to with a big cam and an A4)? How about around the town streetability? You're gonna lose a good bit of the "tight", torquey feeling less overlap cams have to offer.
As far as the bucking and surging, you will have SOME (the degree of which is entirely dependant on how good your tune is). I have yet to see anyone on this site that has eliminated their bucking/surging completely with a big cam; you'll have to live with some.
BTW, if you wanna spray, you're gonna have to think long and hard about your TC choice as you'll need one built to handle the juice. I'm not sure how much stall is too much, cause I haven't done much research, but you'll have to find out.
I'm an extreme beginner when it comes to tuning, but I had a TSP tune to start with as a base and worked long and hard (15+ hours) just on idle/part throttle tuning and didn't get very far. I decided to ditch this cam (which is not considered big), in favor a more tame and driveable GT2-3.
Just some food for thought. I'm sure I'll catch some flack for my comments, but it's just my .02
#39
Ok thanks, yea the converter im getting has the anti-ballooning plates and what not and is nitrous friendly. Ill already lose some driveability with with stall and it will be loose. I dont care about low idle or some minor issues. Long as she pulls like a raped ape, a smile wont leave my face. I think a rumbly lopey idle is effin sweet.
__________________
#40
Well, to me, the torquer 2 pulled like a son of a gun. Man, I had such a huge, TEMPORARY grin on my face from the power I was experiencing. That was until I had to snap back to reality and realize that I'd spend 99% of my time at part throttle where my surging and idle sucked ***.
Seriously though, there are a lot of guys that are very happy with their big cams and have had great success with them. Get a dead-nuts on tune, and you'll probably be good to go. I just didn't think the driveability trade-off was worth it TO ME.
