Milling vs. Smaller head gasket
Old Jan 29, 2006 | 04:00 PM
BADFNZ's Avatar
Default Milling vs. Smaller head gasket
I'm looking for around 11:1 with my LS6 heads. Now I'm deciding on whether or not I should mill or use a smaller gasket. My original choice would be to use the MLS gasket again and mill .030, or mill .015 and use a different gasket with a .040 compressed height. What would be the advantages and disadvantages with either choice?
I personally don't see a difference in either one, because either way the head is going to be the same amount closer to the block. I'm personally leaning to the .030 mill with the MLS gasket because that gasket has alot less issues it seems then the Cometics. Anyone want to talk me out of it?
Old Jan 29, 2006 | 04:23 PM
GuitsBoy's Avatar
Well, every .005 smaller gasket is worth 1cc, whereas youd have to mill .0075 off the head for that same 1cc. Thats because the gasket is the full bore size, where milling the head the actual combustion chamber area is much smaller. Running a smaller gasket also makes for a tighter quench, but you shouldnt run it any closer than .030. keep in mind your piston could come up as much as .010 out of the hole. Youll probably want to do a combination of both milling and a .040 - .045 gasket.
Old Jan 29, 2006 | 04:29 PM
MSGHUFF's Avatar
this thread should answer some of your question:
https://ls1tech.com/forums/advanced-engineering-tech/397179-how-critical-piston-deck-height-quench-distance-ls1.html
I would also do a combination of both mill them .018-.024 and run a .040-.045 gasket
Old Jan 29, 2006 | 11:16 PM
BADFNZ's Avatar
What if I wanted less compression and it came down to doing one or the other, what would you guys suggest?
Old Jan 30, 2006 | 05:17 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Milling.
Old Jan 30, 2006 | 07:42 AM
GuitsBoy's Avatar
I would suggest the head gasket, to a point. A thinner head gasket will make for a tighter quench. Taking the quench down to .030 or .035 will help the fuel/air charge mix and burn more completely in addition to increasing compression. Plus the gead gasket raises compression 50% faster than milling does, so you can raise i more before running into piston to valve issues.
Old Jan 30, 2006 | 07:46 AM
PREDATOR-Z's Avatar
The best way to gain compression is using a thinner gasket.
As said above .040 is perhaps the thinnest for street purposes.
That would gain you ~3 cc.
Milling a head reduces its flow potential, so a head flowing let us say 300 cfm at .600 will not be flowing as much if it is milled. The more you mill, the more you loose.
Old Jan 30, 2006 | 12:52 PM
BADFNZ's Avatar
So what choices in gaskets do I have at .040? Cometic MLS or Felpro? Are the Felpro gaskets MLS or graphite?
Old Jan 30, 2006 | 01:27 PM
GuitsBoy's Avatar
There's also a .042 made by mr. gasket. Its a graphite gasket and its dirt cheap too.
Old Jan 30, 2006 | 01:30 PM
BADFNZ's Avatar
I prefer the MLS because it seems stronger, but it looks like I'll either have to fork out alot of $$$ for the Cometic or use the GM MLS at .054 and mill.
Old Jan 30, 2006 | 04:25 PM
kpforce1's Avatar
When considering something of this nature you need to first consider what will happen to the quench distance... or piston to head deck distance. Stock piston out of the hole is around .007"-.009" and the stock gasket is .054" or so leaving your "stock" quench distance ~.046. You can take this distance to around .040 on a street type application safely. You can run a tighter distance but then rod/piston expansion is more of a factor as well as some other variables. Tightening the quench distance will increase the static compression ratio but will yeild a more efficient burn cycle (increased efficientcy = more resistance to detonation).
To answer you question either is fine unless you are using boost... just keep your quench distance in the .040-.043 range to get a nice improvement with the higher compression without increasing the likelyhood of detonation. Hope this helps.
Scott
Old Jan 30, 2006 | 04:37 PM
BADFNZ's Avatar
So since the stock quench is ~.046", milling .015 or using a gasket with a compressed thickness of .041", would put me at a quench distance in the mid to low .30's, correct? I'm assuming this is pretty tight and I'd start having issues here with valves kissing pistons, but plenty of other people are using the .041 gaskets without any issues, correct? Or are those gaskets used mostly on new engines with a .000" or negative piston height? If .040" is ideal, then would I only mill .006"? This seems low to me.
Old Jan 30, 2006 | 04:56 PM
kpforce1's Avatar
Milling does not affect the quench distance... look through this tech article I wrote... it will help you understand what it is and what affects it: http://forums.corvetteforum.com/show...19&forum_id=48
The article is for Gen I engines but will give you what you need. Only your compressed head gasket thickness and piston deck height will change the quench distance. One thing I didn't mention is that milling can help improve the burn cycle because it "shrinks" the actual head chamber. Look through that link i posted. Hope it helps.
Old Jan 30, 2006 | 06:36 PM
BADFNZ's Avatar
Yes that article helped alot, thanks.
So when applying it to LSX engines, it seems that if the ideal quench is ~.040" and we're already at .046", would a head gasket slightly smaller than stock work best, such as one with a .048" compressed thickness for example? If this is so, how are people getting away with using a .040" gasket without running into any problems? Sorry for so many questions.
Old Jan 30, 2006 | 07:08 PM
cyphur's Avatar
fwiw, I chose to mill .035 and use a .045 gasket, running 241's.
this was with mahle pistons w/4cc valve reliefs. could have milled less with a thinner gasket - but that would have brought quench down ever furhter - and its a street car/daily driver so i chose the thicker gasket.
Old Jan 30, 2006 | 07:22 PM
kpforce1's Avatar
I'm glad the write up helped... Remember that the LSx typ engine was developed to be a more efficient performance engine (hence the tighter quench over the Gen I and II's). You can run tighter quench distance on LSx type engines (~.034") or any engine for that matter you just have to be aware of what is involved. Sure people are running some pretty short gaskets and they are hopefully (but not likely) aware of the risks. Most people don't fully understand what "quench distance" is. When running tighter distances the block deck, head deck, and piston height all need to be checked closely because you have less room for deck height imperfections. Piston to valve clearances must also be examined more closely.
Don't get me wrong here... I'm not saying you cant run a certain quench distance, you can run what ever quench distance you want because it is your engine. I'm just pointing out importaint info I've found through my own experience as well as many other profound engine enthusists. Just be aware there is a higher risk of something going wrong within the tighter tolerances. At least you are now armed with more information on the topic to help you figure out what is best for your application.
Old Jan 30, 2006 | 07:47 PM
GuitsBoy's Avatar
Since search was broken, im gonna threadjack off to a quick tangent... Whats the most you can mill before running into problems with the intake? I seem to remember .050 being the magic number. Im aware of the other consequences of milling.
Old Jan 30, 2006 | 08:01 PM
kpforce1's Avatar
I think i've seen people say that .030" is how far they would go without doing some minor port matching or intake "shaving"... but then again i could be wrong.
Old Jan 30, 2006 | 09:06 PM
BADFNZ's Avatar
Wouldn't milling and going with a smaller gasket have the same effect on the intake? If both were done the same amount of course.
