What would cause....
Old Feb 2, 2006 | 05:06 PM
Mr. Luos's Avatar
Default What would cause....
red hot headers??
I noticed after running lightly for a couple minutes that my Kooks were starting to look red. I wasn't sure if this was normal...so I turned the car off.
Car is running quite rich....could that cause it?
Old Feb 2, 2006 | 07:46 PM
SSPerformance's Avatar
when my lt1 car was runing lean it was doing that
Old Feb 2, 2006 | 07:55 PM
Mr. Luos's Avatar
Well...if it is lean I am lost.
Acting like it is WAY too rich at idle and lower RPM's.
goober35's Avatar
Do you have cats.
Old Feb 2, 2006 | 08:00 PM
GT Griller's Avatar
Yea i would think lean would make them hotter...kinda strange.
Old Feb 2, 2006 | 08:04 PM
Mr. Luos's Avatar
Originally Posted by goober35
Do you have cats.
nope, just pipe
Old Feb 2, 2006 | 08:08 PM
goober35's Avatar
hmm.
Do you know how lean your car is running. A lean motor tends to run a lot hotter.
Old Feb 2, 2006 | 08:12 PM
Mr. Luos's Avatar
The odd part is...seems to be acting like it is running rich.
When it idles I swear I am going to start crying.
Backfires at idle....not terrible, just a little popping. Tune is obviously off.
When driving...it hesitates badly under 3500. Over that is acts fine. But a local shop but a base tune on it for now.
When it hesitates...it has shot some fire out the rear.
Obviously not driving it much right now. I had just cleaned the MAF, replaced the O2's and wanted to see if it helped.
Old Feb 2, 2006 | 08:19 PM
redtail2426's Avatar
its running way to lean,dont wait long to get it fixed.
Old Feb 2, 2006 | 10:25 PM
P Mack's Avatar
Have you done any work involving the valvetrain lately?
Old Feb 3, 2006 | 07:16 AM
Mr. Luos's Avatar
Tons.
Big cam, new heads, new motor.
What do you need to know??
Old Feb 3, 2006 | 07:25 AM
P Mack's Avatar
Exhaust lifter preload. If you're holding the exhaust valves open that cause backfiring and red hot headers.
Old Feb 3, 2006 | 08:19 AM
SAM98WS6's Avatar
running rich causes that...unburned fuel in the pipes...then it ignites
Old Feb 3, 2006 | 04:59 PM
Mr. Luos's Avatar
Too much?
I had read that the Morels with stock rockers were a 22 ft/pound install.
What about too much spark advance down low? What is too much as well?
Old Feb 3, 2006 | 06:30 PM
P Mack's Avatar
22 ft lb is not a preload value, it's a torque for the bolts. Did you measure your preload? Too much spark advance would not cause your problems.
Old Feb 3, 2006 | 06:36 PM
Mr. Luos's Avatar
I did not measure preload. I had read to install the rockers to 22 ft/pounds with the Morel lifters and they would be fine.
I do believe I may have found the problem though. Vacuum leak. Gonna fix it tomorrow.
I made a stupid mistake and forgot to replace the LS1 valley cover bolts with the ones provided from FAST. Hopefully the intake isn't cracked.....
