The Biggest Cam??
Old Feb 7, 2006 | 06:40 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by NOS USER
i like the MS3 cuz it`s will work with heads but i need cam without the use of heads mmmmm im tryin to find new big cams like trex killer jeo on his site said thats you can use it with stock block & stock LS1/LS6 heads sound cool but im looking for somethings thats kicks the trex killer a$$
Then you need to get some valve relief'd pistons and run a solid roller. Somewhere in the range of 27X/28X .7XX/.7XX .
Old Feb 7, 2006 | 06:48 AM
777's Avatar
777
You can get a custom grind cam from a few people. I have seen some quite a big bigger than the t-rex without the need for flycutting. However, you aren't really thinking about what you want really. You need to look at what's possible and what's not. For example you are not going to get 550rwhp out of stock heads 346ci ls1.
Old Feb 7, 2006 | 06:51 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If that was the case we would all have the cam.
Old Feb 7, 2006 | 12:05 PM
NOS USER's Avatar
yeah i saw someone on ls1 cam only dyno thread hittin 460rwhp with only cam without flycutting the pistons & with stock LS1 heads so i need something like thats come on guys 460 rwhp without spending more $$$ on the car thats so cool!!
Old Feb 7, 2006 | 12:33 PM
NOS USER's Avatar
any idea for big custom cam? please put the lifts , the durations yeah thats for stock block, stock heads & without flycuts the pistons.
Old Feb 7, 2006 | 12:41 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Just go with the MS3 since you will be spraying.
Old Feb 7, 2006 | 01:36 PM
NOS USER's Avatar
i know the MS3 its a powerful cam with a good response for the nitrous but im looking for new idea with something more powerful with more NA RWHP & N2O RWHP so any new idea for a custom cam ?
Old Feb 7, 2006 | 01:51 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Decent ported heads can be had for only $850 these days.
Old Feb 7, 2006 | 08:46 PM
NOS USER's Avatar
Ok im lookin for the Prc 5.3 heads + cam packages & i want to choose the MS3 so what`s the right purshods length for it ?
Thanks.
Old Feb 7, 2006 | 10:24 PM
obrien24's Avatar
I would call tsp and talk with them. They will be able to answer all your questions, since its their setup you want to use.
Old Feb 7, 2006 | 10:31 PM
Jpr5690's Avatar
stock leginth pushrods for the ms3 prc combo and make sure to get the heads with reesessed valves if you wanna use the ms3
Old Feb 8, 2006 | 05:55 AM
  #32
PREDATOR-Z's Avatar
With unmilled heads and recessed valves + stock gasket 7.40 p-rods will be too short.
Most likely you'll have to shim the rocker stand to center your geometry and once you do that, p-rod length increases.
Do not take anyone's word for it, MEASURE it to get it right.
Old Feb 8, 2006 | 08:10 AM
  #33
Jpr5690's Avatar
Ms3 Cam, Reesessed Valves On Prc Stage 2.5 5.3l Heads Stock Graphite Gaskets And Stock Leginth Phshrods Are Exactly Whati Running .. It Allseems To Be Working Great .. Hell, You Helped Me Pick This Setup And Its Been Verified By Tsp
Old Feb 8, 2006 | 08:46 AM
  #34
PREDATOR-Z's Avatar
yeah, I know, but I'm a maniac when it comes to tolerances.
I like a well centered wip on my valves and as close to stock preload as I can get, for noise pupose.
Are you getting some valvetrain noise, like sewing machine?
See, most vendors usually recommend 7.40 p-rods with their setups.
TSP did the same with my PRC/Torquer V2.
But I knew from having my XE-R .581 lift with the same heads, that 7.4s will be noisy and that is why switched to 7.425 wich cured 90% of the excess valvetrain noise and got me into the .05x range preload.
Old Feb 8, 2006 | 10:45 AM
  #35
NOS USER's Avatar
So it`s 7.40 with the Prc 5.3 heads?
Old Feb 8, 2006 | 11:31 AM
  #36
PREDATOR-Z's Avatar
Unmilled with stock gasket, that is what TSP suggests.
I, myself run 7.425
Old Feb 8, 2006 | 04:11 PM
  #37
NOS USER's Avatar
Ok thanks wish me luck with this combo
Old Feb 8, 2006 | 04:48 PM
  #38
Jpr5690's Avatar
yes it is noisy ill admit that
Old Feb 9, 2006 | 12:14 AM
  #39
NOS USER's Avatar
Ok with this combo i`ll use 7.425 purshods lenght but the heads will be unmilled ?? let me send private for jason but he doesn`t response for the full msg`s
Old Feb 9, 2006 | 12:46 AM
  #40
Jpr5690's Avatar
you cant mill the heads with a ms3 cam without flycutting the pistions.. hell you even must request a modfied head (reesessed valves) just to use a cam that big as far as pushrdos go i went 7.40 and it works fine for me but predator does know his **** so hes probally right in saying the larger pushrod would allow for a better fit but i do know 7.40 works fine
