The Biggest Cam??
Old Feb 6, 2006 | 03:21 AM
NOS USER's Avatar
Question The Biggest Cam??
What`s the biggest cam that can i use with stock heads & stock block without flycuts the pistons?
Old Feb 6, 2006 | 03:39 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
T-Rex is really big and will work on stock heads no fly cut.
Old Feb 6, 2006 | 03:41 AM
BlackHawk T/A's Avatar
Why do you want the "biggest"? Just because you can run insane duration and lift doesn't mean it's going to be usable...
Old Feb 6, 2006 | 04:20 AM
NOS USER's Avatar
Blackhawk because it`s less $$$ from the heads+cam combo
Old Feb 6, 2006 | 04:25 AM
NOS USER's Avatar
anyone else with other idea?
Old Feb 6, 2006 | 04:30 AM
DocEwww's Avatar
TR's T-Rex is
Old Feb 6, 2006 | 04:31 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
From your username i assume that you are going to spray this cam?
Old Feb 6, 2006 | 04:59 AM
NOS USER's Avatar
Yes i am going to spray this cam so any suggest ?
Old Feb 6, 2006 | 05:11 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
MS3? I think that there are a few people around here that spray it.
Old Feb 6, 2006 | 09:15 AM
NOS USER's Avatar
any more idea?
Old Feb 6, 2006 | 09:24 AM
PREDATOR-Z's Avatar
T-Rex, MS3, G5X4, FM15, and of course some custom grinds........EDC, HPE etc.....
Old Feb 6, 2006 | 10:27 AM
Robinator's Avatar
TSP Magic stick.
Old Feb 6, 2006 | 12:31 PM
Matt D's Avatar
Retired Street Racer
Holla
Old Feb 6, 2006 | 01:17 PM
ELMiN8oR's Avatar
Originally Posted by Robinator
TSP Magic stick.
is it better then Comp Cams i mean the TSP MagicSticks
Old Feb 6, 2006 | 03:38 PM
NOS USER's Avatar
any new cams different of those T-Rex, MS3, G5X4, FM15 ????
Old Feb 6, 2006 | 05:19 PM
walker94z28's Avatar
I have a MS3 and man it loves the jug. I spray it and hold on. But a big converter is needed, I found that out. MS3 and 4400, youll be fine.
Old Feb 6, 2006 | 06:05 PM
NOS USER's Avatar
i like the MS3 cuz it`s will work with heads but i need cam without the use of heads mmmmm im tryin to find new big cams like trex killer jeo on his site said thats you can use it with stock block & stock LS1/LS6 heads sound cool but im looking for somethings thats kicks the trex killer a$$
Old Feb 7, 2006 | 06:12 AM
PREDATOR-Z's Avatar
Problem is that when you spray, you do not need such a big stall since spray will increase your stall.
That is why I use a VIG 3200
A 4000 stall 2.4 str will act like a 4800 stall under juice if you see what I mean.
Old Feb 7, 2006 | 06:18 AM
obrien24's Avatar
I just had the ms3 put in my car. I am running stock heads. I made 413/380 through a 12 bolt. I will let you know when I find out what it makes on the nitrous, hopefully later today.
Old Feb 7, 2006 | 06:38 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
A 4400 converter will flash at about 5200 on the progressive squeeze...just FYI.
