How much would/should a shop charge to install a cam? And how much to tune it?
I've made up my mind to go with TR230 Cam
I think with the M6 its gonna be about the biggest cam I can go with and still be fairly streetable, BUT I'm now debating on installing the cam myself or paying a shop to do it since I'm kinda stretched for time anymore. Then after I get the cam in I know with a cam that size I'll need a good shop to tune it so I can get all the benefist out of it.. what kinda prices should I look for an install, and what prices for a tuning? Thanks fellas
Brandon
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Brandon
I've heard of shops charging anywhere from $300-$600 for just a friggin cam install. Do yourself a favor and wait for one weekend to set aside for a camp swap using the ls1howto instructions here: http://www.ls1howto.com/index.php?article=23 . It should only take you a day at most, but a weekend leaves a bit of leeway so you can take your time if it's your first time. It's really not that hard at all, and it's a bit easier if you have a helping hand, but it's not absolutely necessary, i just helps in situations like pulling the radiator. Also, by saving this money you can put it towards the tune which I would say runs in the $300-$500 category for a good tune with HPTuners. Good luck with whatever you decide.
BTW, where are you located? I'm sure someone on here can tell you of a good tuner in your area or even help you with the swap.
im gonna do mine to save some money along with a buddy that knows what he's doin to make it easier on myself...but i checked at my local performance shop, and they charge 300 bucks for full cam swap, including springs, pushrods, ect...
as for tuning...a guy her locally (knoxville, TN) who has been on the cover of HPP like 5 times tunes and he only charges dyno time (150 bucks) but then i have seen others who charge 400-600 bucks PLUS dyno time (100+ bucks an hour)
