prc's vs patriot
AFR has its own casting, while most patriot heads are GM castings, some with weld filled chambers to reduce combustion chamber. Patriot also offers their own castings. The AFRs (and ETP heads) are absolutely top notch when you need to squeek out every last HP, but theyre going to cost you. With patriot, you can get plenty of performance out of their heads, with a MUCH smaller price tag. Personally, I cant see spending more than double the price for only 5% - 10% higher flow. However if i was in a different financial situation, my views would be different.
AFR heads are an aftermarket casting. We will soon be releasing our own Predator castings. Our Predator heads will have a thick deck surface, beefed up rocker and springs pads, 3 runner versions, and custom chambers that are made to your specs. As with our LS6 style heads, these custom chambers will be done by CNC maching and not by milling the heads. These, like our current OEM heads, will be very high quality and comparible in performance and flow to other aftermarket heads available. Pricing on these heads will be less than the heads in the same class.
What would be the price on the prc including all that?Can anyone inform me?
Thanks
Thanks
Thanks
Dont get me wrong, the TSP guys are good guys as well. Theyll take care of you as well, however theyre distracted in many directions. Gunnar eats, breathes and dreams cylinder heads. The support he gives even way after the sale is legendary.
Get some side by side price quotes, and then compare dyno graphs of cars that have similar setups. That should help you decide fairly quickly. Both companies have great CS.
I won't spend a lot of time talking different products, just look at recent results in the dyno section
I think you'll like the PRC results
Jon
Texas Speed
www.texas-speed.com
I want to purchase your product, but I am STILL waiting for a response from either you or Jason on my specific questions. I've sent 4 emails/PMs in the last 1.5 weeks and no response....??????
Li'l help!?
If you're putting improved ZO6 heads on an f-body, how can they be budget heads, except for the COST relative to small niche aftermarket cyclinder head businesses? How could a small business compete with a monster like GM in a price war? They can't.
It just seems that people who have spent a lot of money on heads need to put down LS6 heads to feel like they got their money's worth. Straight up, that's the way it seems to me. Sorry if I offended anyone.
