should i switch to thicker oil?
Old Feb 12, 2006 | 09:00 PM
619SS's Avatar
Unhappy should i switch to thicker oil?
hey fellas .. today i was drivin down the freeway ( drivin it pretty hard) and noticed when i got off to a light that my oil pressure was around 20 psi which is wierd cuz usually idles around 35-40 when itz warm and when itz cold ruffly around 50-60 now when im driving goes back up to around 40-50 .......i use vavoline 10-30 was wondering if any of u guyz had this problem or should i go with a thicker oil i dunno kinda lost for words ne advice would help thx..
Old Feb 12, 2006 | 09:20 PM
ShevrolayZ28's Avatar
How many miles are on the car?
...Unfortunately, thicker oil is not going to fix anything.
Old Feb 12, 2006 | 09:31 PM
619SS's Avatar
bout 130xxx miles but i just rebuild engine liek a 2 months was runnin fine....
Old Feb 12, 2006 | 09:34 PM
ss rally red's Avatar
Thicker oil will usually raise oil pressure in most cases but its a band aid for some other problem.
Old Feb 12, 2006 | 09:45 PM
DocEwww's Avatar
130K on ur oil pump?
Old Feb 12, 2006 | 09:49 PM
619SS's Avatar
naw itz a new one bout 5k on it.. itz wierd sometimes it even jumps around like twitches from 20-35.. at idle
Old Feb 12, 2006 | 10:43 PM
scrappy983's Avatar
What's your pressure when you accelerate?
Old Feb 12, 2006 | 10:52 PM
619SS's Avatar
like 45-60 when im flooring it like 60+
Old Feb 12, 2006 | 11:00 PM
99camarosupersport's Avatar
is it possible guys that there just may be a "short" or something of the sort in his oil pressure guage?
Old Feb 12, 2006 | 11:05 PM
619SS's Avatar
ya bro i was thinkin that cuz car doesnt preform any worse or make any noise or nothin.. but what do i know lol thats why im askin for help how would i check that btw.. if there is some "short"
Old Feb 12, 2006 | 11:09 PM
scrappy983's Avatar
Chance of your transducer ( the electrical pressure gauge that moves your panel gauge) is unlikely. A Diagnostic tuner could tell you. Are there any puddles when you stop...Are you burning it? What's the exhaust color?
Old Feb 12, 2006 | 11:24 PM
619SS's Avatar
naw bro ...no puddles.. not burning anything (cept lil more oil than usual just thought it would be the shorties... had em for like 2k miles ) i cant see any colors in the exhaust..
Old Feb 12, 2006 | 11:33 PM
scrappy983's Avatar
Not sure. I would say a compression test, to check your rings. Get your oil lines blown out. Low pressure air. After that if it's still low...Probably have a clog in your block. The oil goes thru the block to lubricate the pistons...If none of that....Ummm..My boy says drive it down here and he'll run it over for ya. Cuz we're all out of ideas
Old Feb 12, 2006 | 11:46 PM
619SS's Avatar
where ya located?
Old Feb 12, 2006 | 11:51 PM
scrappy983's Avatar
South Texas..He's runnin' over my avenger at the end of the month. It's amazing what rednecks in the military do for fun
Old Feb 13, 2006 | 12:12 AM
SUTTERERMAN85's Avatar
i run Val 10-40 in my 130k motor that is cammed and i abuse it alot. when the oil gets hot the viscosity is lower hence lower oil pressure
Old Feb 13, 2006 | 12:25 AM
P Mack's Avatar
Three things come together to make your oil pressure lower when you've been running it hard. The oil becomes thnner when it's hot, your clearances become larger because the block is hot, and the idle rpm is lower when the engine is fully warm causing the oil pump to not spin as fast. Mine does the same thing after getting a new shortblock, it will be 40 psi at idle when it's warmed up, but only after driving for half an hour or so it is down to 25 psi. As for the oil pressure twitching, if you watch closely you'll find that it twitches as the idle rpm twitches.
Old Feb 14, 2006 | 11:36 PM
619SS's Avatar
only the oil pressure gauge twitches .....the rpm gauge remains at 1100 doesnt move at all... but what u said makes perfect sense though...
