CNC track lines on intake runner
There are inherent flaws from CNC machines that hand porting can take away. There seemed to be a ridge from where the CNC machine couldn't go any further from one direction that I was able to take down and make it smooth. I've seen this in many different pics from different companies. It's hard to see, but you can feel it when you run your finger over it. That itself convinved me why I should touch up the intake. I have plenty of time until I'm going to be installing these, so I decided to go the extra mile.
I'm not staying with the 224 cam for forever, so maybe one day my efforts will pay off
No disrespect here, I appreciate all the posts. Many of you have much much more experience than I do.
Yes, these are Mikey's creation!
Chamber
Intake
Chamber
Exhaust
Chamber...again
Was it worth my time? Yes, because I enjoy that sorta stuff and they're better than they were before. Would it be worth someone elses time? Probably not.
I've been told that handfinishing will result anywhere from 1 to 2 percent gain in airflow. Doesn't sound like much but with my heads that'll range from 3-6 cfm. I'll take that! I also had a lot of time from when I'd be able to put the heads on. The blending of the valve guide could have used some work too. That was reason enough for me.
Besides, they look better
Just some free tech information!!!
John
Dart
John
Dart
In a real life scenario there would be no use to the ridges from the cnc machine because the fuel had little to no contact to the part of the head that originally had cnc marks. It's not like the fuel is flowing all through the head like it would be in wet flow test. The area near the base of the valve seat hardly had any cnc marks to begin with and that is about the only spot where fuel will have contact to the intake port.
I'd love to see some back to back comparisons on this.
FUEL INJECTION: What is the first word there, FUEL, yes its injected further downstream from from the throttle body, but it isnt like a down nozzle on a sprint car. So fuel is still entering the port, how do you think we test on a wet bench? Just like an injected car, the fuel is added to the air stream just prior to it entering the intake port, so yes it makes a difference.
We have tested this, and we have worked with fuel injection, we know it still makes difference. But if you dont want to believe thats cool, do it your way. Just giving away more free information, that people once again want to dispute.
John
Dart
By the way I appreciate all the advice and the "free information"
Could you elaborate on the test scenario though John? I'm just curious.
