View Poll Results: Get rid of CNC track lines on the intake runners?
Yes
21
23.08%
No
70
76.92%
Voters: 91. You may not vote on this poll
CNC track lines on intake runner
Old Apr 21, 2006 | 03:30 PM
  #81
Xtnct00WS6's Avatar
Originally Posted by Malihoochie
It was a comment made long ago. Many people don't realize that CNC machines have been around since the '70's. Technology marches along at a rapid clip. Many head gurus say the grooves left by the CNC causes a vortice, where the air getts trapped and in turn acts like a roller for the incoming air. And, to add to the mix, our top porter feels that a roughened surface (very rough) is probably better yet. Lasershops heads do look sweet tho'. Like they should be on a display for a brand of metal polish.
The article said 2001. Did you already get to talk with him?
So you think a "very rough" surface is even better than CNC marks? Is that what ur saying? So maybe I WILL be fine Trust me, my heads are gonna be rougher than an old mans 5 o'clock shadow.
Old Apr 21, 2006 | 03:35 PM
  #82
Malihoochie's Avatar
Dart331stroker spoke with him about 30 minutes ago - I had my own stuff going on, so don't even know if it was mentioned.
Old Apr 21, 2006 | 03:43 PM
  #83
gollum's Avatar
Malihoochie, Can you post pictures of Darts Wet Flow bench?
Here is a short description of it:
P.S. There wet flow bench is the most fantastic thing ever conceived for cylinder head R&D. I spent most of my time up there on that thing. Its the largest bench I have ever seen. When this thing fires up it sounds like a turbine engine spooling up. You think the pictures I had where mind blowing, think about actually watching the atomization plume as well as viewing and plotting the angular discharge of the mixture! Its simply mind blowing. I have asked Richard if I can take some pictures and video, he assures me that will not be a problem.
_________________
Darin Morgan
R&D-Cylinder Head Dept.
Reher-Morrison Racing Engines
Old Apr 21, 2006 | 03:49 PM
  #84
I could E-mail you a pic - maybe you could post it?
  #85
Xtnct00WS6's Avatar
Hell yeah. Let's see some vids of a Dart head being wet flowed. If anyone is so inclined, maybe we could get a brief description of why it flows as well as it does based on what we're seeing on the video.
Old Apr 21, 2006 | 03:50 PM
  #86
Jeff Smith from CarCraft was here last week for 3 days & is doing a big write up on wet flow.
Old Apr 21, 2006 | 04:05 PM
  #87
Gollum - sent ya 3 pics.
Old Apr 21, 2006 | 04:12 PM
  #88
gollum's Avatar
Did not receive. Please read latest PM.
Old Apr 21, 2006 | 04:30 PM
  #89
Did that the 1st time, but resent.
Old Apr 21, 2006 | 04:35 PM
  #90
gollum's Avatar
Looks like we'll have to wait for the CAR CRAFT article.
Old Apr 21, 2006 | 04:39 PM
  #91
I just re-sent them again, but in singles this time. Maybe the pics were to big before?
Old Apr 21, 2006 | 04:59 PM
  #92
gollum's Avatar
OK...Here it is...DARTS WET FLOW BENCH !
Attached Thumbnails CNC track lines on intake runner-2006_03150055.jpg   CNC track lines on intake runner-2006_03150056.jpg   CNC track lines on intake runner-2006_03150057.jpg
Old Apr 21, 2006 | 05:03 PM
  #93
Xtnct00WS6's Avatar
Is this going to be posted on LS1tech?
By the way, about your comment about the vortice...
When you were referring to your top head porters and them saying that the "very rough" surface is probably better, are they talking about hand porting or cnc marks? Combination of both? Are they basically saying a "very rough" surface from something like a 40-50 grit sandpaper is even better than CNC marks?
Thanks
Old Apr 21, 2006 | 05:23 PM
  #94
Really rough - like hit with gravel rough. My own heads (old school small block) will be flowed very soon and the intakes were ported then "roughed" with a course carbide bit. A previous post on this site had some folks saying the blending on our LS1 heads looked crude or some such ... that was deliberate. Call it crazy, but ugly is fast!
Old Apr 21, 2006 | 05:26 PM
  #95
Bravo Gollum!! The pics finally made it!
Old Apr 25, 2006 | 01:01 PM
  #96
Gunnar@Patriot's Avatar
Originally Posted by Lasershop
You've seen my heads Gunnar. No ones are as smooth and polished as mine. Ill take you up on that.
Let us know when you are ready.
Old Apr 25, 2006 | 01:10 PM
  #97
Xtnct00WS6's Avatar
Lasershop,
If you're going to get them reflowed, you might want to consider skuffing up the intakes on one head and keeping them as you have them on the other and seeing how they compare. As nice as they look now, I think u'll be holding back ur power potential with polished intake ports. I've done this w/ my heads and I *should* have results by tonight. We'll see though...
Old Apr 25, 2006 | 01:42 PM
  #98
PortPros1's Avatar
Pretty sure Port Pro's only hand port heads. Altering the material in the runner can change the flow of the cylinder head. If you do hand finish these, make sure as you stated before not to polish the runner. Keep in mind that any material you remove can change the flow of the head. We suggest that the heads remain the way we send them out unless the person doing the finishing has knowledge of porting. We have seen cases where "just cleaning them up" has reduced the flow on a set of heads.
I wouldn't suggest smoothing the runners in your heads, our finish comes from many hours of flow testing and years of experience. If you’re not an experienced head porter with a flow bench, I would suggest you leave the heads as you bought them.
Old Apr 25, 2006 | 01:53 PM
  #99
Lasershop's Avatar
It will cost me how much?
Old Apr 25, 2006 | 02:04 PM
  #100
Lasershop's Avatar
Originally Posted by Xtnct00WS6
Lasershop,
I would like to have these flowed but Im not going to change their appearance regardless of the outcome. I have way too much work involved. The numbers would be interesting being how these are an extreme case of hand finishing. Motor will have more power than I could ever possibly use as it is and the car itself will be transported by trailer from show to show. Now next year when I start to build my LS1 powered front engine dragster...... How I do things will be all business.
