CNC track lines on intake runner
Hopefully I didn't screw them up too bad. What kind of finish do you guys use for the intake ports if you don't mind me asking. Do you polish up the combustion chamber?
RonO
The one interesting thing I found out was that the surface with the *very very rough* finish flowed 1.5 cmf LESS than the smoother one. It was a difference between about a 120ish grit and about a 50 grit finish. Maybe the actual port was the reason for the difference, not the surface texture. Wierd?!
what does skuff means ?
and why it made him nearly cry? (maybe the meaning of skuff answers that)another question is about the wetflow being the best of all method to flow a head and that it`s more to a real world measure .....
so if on the same car a AFR 205 and a DART 205 same valves sizes and springs etc ... we will see better rwhp and track time of the same everything else but the heads(cam 60`s numbers weather)....because the DART`s is the best of the best (both their own castings DART`s being the wetflowed ones) .... I think it`s a good question anybody agrees?
very informative thread (smooth intake runner doesn`t mean better because the marks contribute to faster dense mixture flow) didn`t know that.
What's wierd is that when I flowed my heads, the smoother intake runner came out to be the better one by 1 cfm. I'm still going with the relatively rough surface texture though. The guy I got my heads flowed by is on really good terms with Joe Mondello so he called and asked what the surface should be and he said 60 grit finish. So that's what it'll be. I even made the point of making sure he mentioned what kind of heads I have too. I'm prolly starting the install tonight or tomorrow since I just passed emissions
Now I'm good to go!Btw...skuff means to roughen up the texture.
thanks for the clarification ....
what I said was :
dart using the wet flow bench (the best)
afr (assuming) normal bench
dart and afr use their own castings and port designs on stock valve angle
equales dart 205cc = better than afr 205cc in the REAL world track racing on nothing but a heads change between them since it was done on the super duper wet flow bench!
(if that is true the the platinum Iron Eagle is a really good head to consider since it was wet flow improved)<----that`s not the subject just a thought
My guess is that its worth nothing. Leave them alone. It can be tempting to "go the extra mile" but I think you're going to be wasting cartridge rolls
. Ryan
https://ls1tech.com/forums/generation-iii-internal-engine/501812-lasershop-s-patriots-reflowed.html
Interesting how the actual head porters here have say one thing and the amateur experts say another.
Also if you dont have the right equiptment on your flow bench I dont see how you can say "you've never had a head flow the advertised numbers" and be accurate about it.
You havent duplicated the test so you really cant say one way or the other.
Atmomization isnt just and old school term and still applies today. That air and fuel still need to mix on their way into the combustion chamber to maximize combustion. If mixing the air and fuel wasnt needed then injection would be direct into the cylinder.
https://ls1tech.com/forums/showthread.php?t=501812
This flow doesn't mean that they will perform well in real motor environment. Atomisation is gonna be seriously affected.
Super Bling but, polishing intake runners damages the performance.
Ouside bling is awsome."
You just dont seem to want to listen to anyone but yourself so you go ahead. He didnt see a 1% gain, he saw eradic results with losses in some areas. In general the performance of those heads have been compromised. But you dont want to listen to fuel atomization because you think you know more than the pro's do...
good luck I'm out. Interesting how the actual head porters here have say one thing and the amateur experts say another.
I think for the most part everyone is in agreement here. We agree that a rough intake port is optimal. There's no confusion between the pro's and amateurs. I believe that the rough port is optimal because it's mostly an issue of fuel flow and not atomization.
In regards to not getting "the advertised numbers", it's pretty common to have differences between flow benches. The guy that flowed my heads said his bench almost never flows the publicized numbers. He also flowed them on a different bore size too. I do have 401/392 on a Mustang Dyno with a small cam, cats, and an LS1 intake. I think the heads ended up being JUST FINE
EDIT...I don't want to mislead anyone. He gained airflow, but fuelflow will now suffer since the intake wall is too smooth.
It was me that missed some posts not some posts that were missing!
