crane 1.7 accelerated rockers and tsp ms3?
Old Feb 14, 2006 | 04:27 PM
SVC707's Avatar
Default crane 1.7 accelerated rockers and tsp ms3?
will these work together... with stock heads or afr's or do i have to take them off.
i could put these in my truck cant I? hmm just another thought
Old Feb 15, 2006 | 06:25 PM
mrr23's Avatar
yes, they will work. the max lift ratio will be 1.72 ratio. the beginning ratio is 1.79 until about .250-.300 lift.
Old Feb 15, 2006 | 07:05 PM
vettenuts's Avatar
Just make sure to check your wipe pattern with your new setup.
Old Feb 17, 2006 | 07:40 PM
SVC707's Avatar
wipe pattern?
and i just remebered that the rocker arm came with shorter pushrods too so i should be ok huh?
Old Feb 18, 2006 | 07:25 AM
MNR-0's Avatar
Yes. The rockers are adjustable so just make sure your preload is set. Shorter pushrods are better for higher RPM.
Old Feb 18, 2006 | 10:54 AM
SVC707's Avatar
so i guess i can keep these rocker arms and switch over to the tsp cam....
Old Feb 18, 2006 | 11:03 AM
kenp's Avatar
It'll all revolve around your valve springs won't it?
Old Feb 18, 2006 | 09:13 PM
SVC707's Avatar
can you guys tell me which springs to get as i know i need better springs
Old Feb 19, 2006 | 06:51 AM
mrr23's Avatar
whatever springs TSP says to use with their cam.
