Someone with Cam Doctor check this cam?
Hi, It is a custom grind from Comp Cams for my CTS-V. Looking for thoughts on cam timing and its use in my application. Here are the specs:
LS1 XE-R Lobes: 3720/3722
Gross Lift: .581/.581
Lobe Lift: .342/.342
Duration:
.006 269/273
.050 220/224
Timing @ .050
Int: 0* BTDC 40* ABDC
Exh: 50* BBDC -6 ATDC
LSA: 114* ICL Installed: 110*
Any thoughts on whether to install with advance, straight up or retarded?
Mods: CAI, Shaner Ported Throttle Body, 170* Thermostat, Kook's Headers, Cat Back Magnaflow, DTE Stage II Tune, Aluminum Flywheel, Underdrive Pulley, Dart Heads; Daily Driven 20k+ each year.
Thanks in advance, Mickey
Duration:
.006 269/273
.050 220/224
Timing @ .050
Duration:
.006 269/273
.050 220/224
Timing @ .050
Duration:
.006 269/273
.050 220/224
Timing @ .050
Thanks for the info guys. By straight up I meant installing it with an ICL of 114 which would actually be 4* retard for this one.
Dyno Tech Engineering tuned it based on a CTS-V with exhaust and cold air kit.
Any thoughts on the best way to install this cam and if it seems like a good cam for daily driving with some 1/4 mile? Car has run 12.89 @ 112 without the headers, heads and cam (which will be installed at the same time)
Thanks again, MIckey
judging by it's size, it should be a very mild mannered street cam that'll give you a kick in the ***
they mean installed dot to dot - you can check out exactly what they are referring to in the cam install guide on ls1howto.com - there's obvious differences between the cars on the site and yours but the internal engine stuff is the same
