comp cam 228/230 571/573 114 who has one?
oh ok, just wondering. ive seen alot of thread on these comp 228/230 cams. Ive been looking around at cams and alot of people recommend for mild applications between 224 and 228 is a good cam size for us relitivly stock 5.7s. ive been dead set on 228R but if a good deal on a 228/230 cam came up, It woundnt be a bad compromise would it?
Changed from it to a 228R and picked up 28rwhp.
01 WS6, 6spd, stock heads, LT's, UDP and FAST 90.
Unless you can get the 228/230 REALLY cheap I'd spend the extra dough for a 228r and be done with it. To save a couple hundred bucks only to tear back into it and stick a different cam in it later isn't really worth it IMO.
ok ok! thats the awnser i was looking for. i came across one for about $180 on ebay but its early yet so im not expecting it to stay there lol
well ill stick to the 228R that i had in mind unless i find the 228/230 for REALLY cheap lol
thanks
thanks
When it comes to cams I have put a cam in because it's cheap only to be frustrated with performance and pull it back out, spending ~$100 on all the BS involved(balancer bolt, coolant, oil change, etc...) plus a weekend and then buying the right cam when I coulda just done it "right" the first time.
Say it goes for $200, you're saving $200 but making ~35hp less. Probably more if you have a FAST. So that's about $6/hp. I'd spend the $200 and buy a 228r.
Just my $.02
Just my $.02
Just my $.02
Just my $.02
Doubt all you want, I tuned it on the same dyno so results should be comparable. Weather was a little cooler when I ran the 228 on it but only about 10*.
I'm not going to argue about it, that was my experience.
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
