Can I get an opinion about this lifter?
Old Feb 20, 2006 | 06:49 PM
jub jub's Avatar
Default Can I get an opinion about this lifter?
This is typical of all 16 of the lifters I pulled from my engine, slight scoring you can't feel with your finger nail. Also slight wear bar around the roller but you can't feel that either. All the rollers have smooth movement.
So what do you think?
Old Feb 20, 2006 | 07:27 PM
SideStep's Avatar
Give me about an hour and I will have mine out... and will compare to your pic. How do the rollers look???
Old Feb 20, 2006 | 07:30 PM
Bimmer Tech's Avatar
Replace them while they're out. It's cheap insurance. You can get a set for under $100.
Old Feb 20, 2006 | 07:37 PM
jub jub's Avatar
Rollers look good. No pitting or anything that you can feel and they roll smooth. I'll probably replace them anyway. BTW, I'm in search of an anoying "tick" that's been bothering me ever since I've had the car.
Old Feb 20, 2006 | 08:29 PM
67Ranger's Avatar
they dont look bad, but i'd replace them with new ones while they're out.
Old Feb 20, 2006 | 08:37 PM
Bryan@LME's Avatar
LS1TECH Sponsor
The lifter looks like it has seen some heat. It's also not the prferred lifter with the open body around the roller. I would replace the lfters.
Old Feb 20, 2006 | 09:17 PM
SideStep's Avatar
Where in the world are you getting a complete set of lifters for under $100?????????????
Old Feb 20, 2006 | 09:18 PM
SideStep's Avatar
Check out my post... same as your but less... Jury is still out
https://ls1tech.com/forums/generation-iii-internal-engine/457262-lifter-bad-56k-beware.html
Old Feb 20, 2006 | 10:21 PM
Ebay. Even Summit Racing has them for around $125 for a set.
Old Feb 21, 2006 | 06:26 AM
GuitsBoy's Avatar
Id say that lifter is okay, but like the others said, might as well replace them now. The side is nothing to worry about. I cant see the roller well enough to tell in tha pic, but if you say its good, than you dont likely have a problem with them.
Old Feb 21, 2006 | 07:29 AM
jub jub's Avatar
I don't know if I would trust a set of lifters that cost around $100 or so. But I do plan on replacing them, the only problem now is trying to decide what lifters to use. I'm thinking either the comp replacement lifter or perhaps the Morels.
Something else to think about. With all the current lifter threads, do you suppose the new generation of steep ramped camshafts is beginning to take it's toll on lifters. It appears the rollers are taking a beating from some of the pics I've seen. Just thinking out loud.
Old Feb 21, 2006 | 05:01 PM
Byter's Avatar
I don't know if their taking a toll on lifters, but I think its a major cause of the ticking and "sewing machine" noises everyone is posting.
Old Feb 21, 2006 | 05:02 PM
Byter's Avatar
Bryan when you say "the prferred lifter with the open body around the roller" you mean like the Comp OE's? Thanks...
Old Feb 21, 2006 | 05:12 PM
98Z28CobraKiller's Avatar
Restricted User
there are ones that are open all the way up like yours and ones that only expose the bottom half of the roller both are stock.
Old Feb 21, 2006 | 05:18 PM
Byter's Avatar
Thanks. My Comp 850's expose only the bottom half of the roller. I was wondering if Bryan preferred the "open" or "bottom half" lifters and why...
Old Feb 21, 2006 | 05:21 PM
PortPros1's Avatar
How many miles do you have on these lifters? They are showing heat, I would what to know why they are showing heat. I also would take a very close look at the lifter bores.
If you just replace the lifters without finding out why they have heat in them your new lifters are going to look the same as the old ones. From the picture it looks like a lot of heat has been through the lifter.
What was your oil pressure like before you pull the motor down? Did you find any trash in the oil?
You can pm me if you like, if you have any more pictures I'd be happy to take a look, better to be safe than sorry.
Old Feb 21, 2006 | 05:28 PM
Restricted User
open is not preffered by anyone. That is why the aftermarket makes them half exposed like the later OEM are. He meant that the pictured "open body" should be replaced regardless. If they were the closed type (OEM), he may be able reuse them.
It is kinda like the crappy old clutch hydrualics. Whether it is causing a problem or not, it should be replaced.
Old Feb 21, 2006 | 05:51 PM
Byter's Avatar
Again, thanks. However if that is true and Morel's are supposed to be the best, then why do the look like this: Morel Lifter Picture P.S. I'm not trying to be an a**hole, I'm just trying to decide whether to replace my Comp 850's with the best lifter
Old Feb 21, 2006 | 08:48 PM
jub jub's Avatar
They are stock with about 20k miles on them. Just checked lifter bores tonight and they all appear to fine. Oil pressure is fine at about 30 psi hot at idle and 50 psi when cruising.
I just ordered a set of Mellings which are fully encapsulated so we'll see how they pan out.
Old Feb 21, 2006 | 09:09 PM
Bryan@LME's Avatar
LS1TECH Sponsor
As said above. The preferred lifter has the lifter body extending down over a portion of the roller. Like the 850's or others. We replace the style of lifter that is pictured. Regardless of condition.
