T-rex Goin In!
Old Feb 22, 2006 | 11:54 AM
2002blkss's Avatar
Exclamation T-rex Goin In!
Im gettin my trex put in today and tomorrow wonder what numbers i might get? Along with cam i will have 4.10 gears spec 3 & fidanza flywheel 42lb injectors flowtech headers ORY ported throttle body intake and bullet muffler!
Old Feb 22, 2006 | 12:03 PM
blkZ28spt's Avatar
391.48429625 rwhp.
Old Feb 22, 2006 | 12:45 PM
alans02z's Avatar
Depending on who tunes it, 410-425.
Old Feb 22, 2006 | 12:48 PM
2002blkss's Avatar
It will be tunned by Next level performance IN florida also know as Norris Motorsports
Old Feb 22, 2006 | 06:12 PM
01350ss's Avatar
don't you think 42lb injectors are a bit much? just curious, cause I'll be putting the same cam in shortly along with 90/90 headers, pulley, tb ect.ect.
Old Feb 22, 2006 | 08:51 PM
mike c.'s Avatar
t-rex is a monster.
Old Feb 22, 2006 | 10:54 PM
ilirw325's Avatar
does a t-rex need flycuts?
JRracing's Avatar
Go big or go home! HAHA.
Old Feb 22, 2006 | 10:56 PM
ShevrolayZ28's Avatar
May the Lord be with your lifters.
Old Feb 23, 2006 | 12:30 AM
35th SS's Avatar
they be alright as long as you dont do it all the time.revvving pass 7k until you upgrade the rod bolts.good luck.
Old Feb 23, 2006 | 01:27 AM
DocEwww's Avatar
Not on stock heads.
I'd say about 400rwhp. No U/D pulley?
Old Feb 23, 2006 | 01:35 AM
TARZAN's Avatar
Just curious....any other supporting mods?
You say "ported throttle body and intake"....does this mean that the intake is ported?
I'm gonna say 405 RWHP
-Will
Old Feb 23, 2006 | 01:37 AM
DocEwww's Avatar
-Will
He didnt say "and", most likely just a ported tb and LS6 intake.
Old Feb 23, 2006 | 01:39 AM
TARZAN's Avatar
I inserted the and....trying to make it a lil more readable lol...I was just curious if he meant LS6 intake, or something like a cold air intake....I didn't wanna make assumptions
-Will
Old Feb 23, 2006 | 09:48 AM
spazzyfry123's Avatar
With the modifications you have, what kind of low-end power will you be losing (if any)? I would really love to have this cam for a daily-driver, but am just concerned about low-end loss. Could I bump the RPMs up to about 1000 for the idle and try that? It will be quite some time before I can do this, but I am just curious.
Old Feb 23, 2006 | 10:24 AM
TARZAN's Avatar
With a cam, you don't HAVE to lose power, in any certain range....Thats why they offer different grind cams....You can get a cam to make power pretty much wherever you want....My car runs strong, though it pulls better after about 3 (you're gonna stay past 3 grand at pretty much any point in a race anyways), and idles fine at about 700 RPM's....Mods in sig..
-Will
Old Feb 23, 2006 | 11:01 AM
2002blkss's Avatar
Yea i have ported throttle body ls6 intake, cam is in and getting tuned tuesday, it acutally is pretty drivable it idles right round 900rpm and drives smooth
Old Feb 23, 2006 | 11:22 AM
92zcamaroperson's Avatar
with that big of a cam his power would be pretty high. If he changed his springs and upgraded the connecting rod bolts could the motor safely hit 7000rpm?
Old Feb 23, 2006 | 12:08 PM
GuitsBoy's Avatar
You have to change the valvesprings to even get the motor to idle. Spinning it up to 7K and higher is all in what youre comfortable doing. Yes rod bolts will help out tremendously. With the T-Rex you'd probably want to spin to 7200-7400.
Old Feb 23, 2006 | 02:28 PM
-Will
Yes, I realize this. However, I am asking my question specifically towards the T-Rex cam since that is what the thread is about.
I really would like to have the cam for a daily-driver. But I don't want it if it's next to impossible to keep the car running and easy to drive stop after stop...
