Whining Noise After Cam Change
#367
After 30miles, absolutely NO whine, and all I did was have it polished.
Very happy I didnt buy a new cam.
Now get to spend that on either full stainless duals and longtubes or a slightly built tranny/converter combo. Cant decide which...
#370
I just want to thank Kip Fabre at Cam Motion on his great customer service & let everyone know that if you have a whining noise coming from your engine after a cam swap it is the Cam. Sent mine to kip at Cam Motion & he polished it & had it back to me the next day. Just installed the Cam back in the car on sunday & NO WHINING!!!! Thanks Again Kip!! I really appreciate what you did for me & I will def spread the word about you guys.
#371
If he never came into this thread I wonder how everything would have turned out for us. He is the man for sure.
#372
If Kip wouldn't have come to this thread, you guys would still have whinning cams, and Comp would still be claiming they haven't heard of such a problem. It really is unfortunate, but until another manufacturer says what the problem is, Comp just denies it. Why couldn't they just do it right the first time? It would have saved you guys the trouble of all the work to change out the cam, and Comp could have kept their reputation in check. In business, word of mouth can either help your business thrive, or kill it.
#373
#374
He sure is!! Good to know there still good people in this world that will help others out when they're having a problem. Damn good guy!!
#375
Up date on a cam that was whining. We received a cam yesterday for inspection and polish. I was wrong about the fine CHATTER it was not fine it was very visible to the eye. Very fine Chatter can still cause whining. It still hard to see if you do not know what you are looking for. The light has to be good.On this cam you could feel it and see it with no problem. After a polish job it looked good to go with out any problems. We shall see.
This alone could save us all a lot of heart ache, and wasted time and money.
EDIT - some interesting reading and a picture: http://www.engineproblem.com.au/camgrind_know.htm
http://www.leabrasive.com/balanced.html
http://www.sciemetric.com/sites/defa...afts_AN192.pdf
#376
The ones with fine chatter are hard to see. The ones we fixed and polished are easy to see. When you receive a cam from anyone you should clean it and do an inspection on the new cam yourself. If it has a computer generated cam card you better check it yourself in the engine if you want to know what you received. If the lobes are polished they should look nice a smooth they should also feel smooth to the touch. To see if there is chatter clean the lobes off and hold the cam in front of yourself horizontally get under a good light and look at the bottom of one lobes get the light to hit the bottom of the lobe and turn the cam so the light will climb up the lobe to the top if it has chatter it will look like it has steps or little flats along the lobe from the base circle to the top all the way around if it does it will WHINE.
Kip, can you help us identify the chatter by providing an idea of what we should be looking for, and how to look for it?
#377
"Grinding chatter marks are often seen on the base circle and the sides of the lobe. Chatter marks can cause hydraulic lifter problems and premature wear. Pronounced chatter marks and eccentricity on the base circle can cause hydraulic lifter pump up and an engine miss on idle."
My lifter tick got pretty bad after these Lunati cams. I'm swapping the lifters this weekend for sure.
#379
Seems to be random. Is yours whinning? If not, you got one that Comp felt like doing right. But beware, if you decide on getting a new Comp grind. As Kip said, inspect the cam as best you can.
