Car is cutting off sayin LOW OIL/ SES
That was gross ^
First things first. Check the oil. Just because you just changed it doesn't mean don't check it. I mean if your low oil light is on, your oil is probably low. That's common sense. Next thing, take it to get the codes scanned. For all you know it could be a faulty maf which would cause every single one of your symptoms. Or it could be a blown fuse (main) and it would cause the maf not to work.
So check oil, check fuses, take car to get it scanned, report back.
