ls6 spring question
Old Mar 1, 2006 | 05:25 PM
Pewter02TA's Avatar
Breakfast Fanatic
Default ls6 spring question
anyone ever herd of running ls6 springs with a stock cam?
Old Mar 1, 2006 | 07:34 PM
kazfan30's Avatar
Uh no........not meaning to offend you, but what would you gain by just running a better than stock spring on a stock cam. You could run 918's with stock cam, but there would be no need unless you were doing a cam later maybe
Old Mar 1, 2006 | 08:14 PM
Mark99Hawk's Avatar
I'm running LS6 springs on the stock cam - no issues here
Mark
Old Mar 1, 2006 | 08:19 PM
2xLS1's Avatar
They have been known to prevent bent push rods if you do the mis shift and mechanically over rev the motor.
Old Mar 2, 2006 | 03:00 PM
Pewter02TA's Avatar
Breakfast Fanatic
Its not for a gain, its so when I rev my car up to where I want too, it doesnt get valve float and just for the extra protection. Since I left the dealership, this car has seen atleast 6,200 every day of its life, and now with 35000 miles, im experencing valve float around 6300.
Thanks guys.
Old Mar 2, 2006 | 04:22 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Works good for insurance that is for sure. I ran 918's on a stock cam with TI retainers for the same reason. No harm in protecting your investment.
Old Mar 2, 2006 | 05:29 PM
Cool Z's Avatar
I'm running 01 LS6 springs in my 2000 Z28. No probs here. I had to replace the stockers at 7500 miles because the valves were floating at 5500 rpm. I have not expirenced valve float since and the car now has 71K on her.
Old Mar 2, 2006 | 05:34 PM
blkbird's Avatar
How can you tell you get valve float?
Old Mar 2, 2006 | 05:38 PM
Cool Z's Avatar
I was losing 40+ RWHP at 5500 rpm's on the dyno. Also, At 5500 it felt as if you let up half off the throttle for a second, then hammered back down on it. It was noticable in 2nd gear, and couldn't miss it in 3rd.
Old Mar 2, 2006 | 11:39 PM
nelson1100's Avatar
Default If you plan on
keeping a stock cam no worries about ls6 springs anything over that get some 26918 springs.
