Is my crank pulley on tight enough?
1. Thread the stud into the end of the crankshaft until it bottoms out. Back the stud out 1 full turn. This will insure that all of the crank threads are supporting the load of pressing the pulley on, but will not bind up the stud in the end of the crank.
2. Position pulley on end of crank.
3. Install large washer, small washer, and nut in that order.
4. Use either a 15/16 or 24mm deep socket to turn nut and press the pulley onto the crank. I do not recommend using an impact gun for this as it will put extreme loads on the threads of the tool.
5. Once the pulley is installed, loosen nut and unscrew the stud from the end of the crank.
6. Install the old crank bolt and tighten to 250 FT/LBS of torque.
7. Install a new bolt and tighten to 37 FT/LBS of torque, then rotate the bolt an additional 140 degrees.
8. If you are using an aftermarket pulley, follow the manufacturer’s recommendations for final tightening.
Use a sharpie and mark the bolt at 12:00 and the pulley at ~4:30. Tighten the new bolt until the marks line up. IF YOU DON"T HAvE THE TOOLS TO TIGHTEN THE BOLT CORRECTLY, GO GET THEM.
Otherwise this will happen to you:
https://ls1tech.com/forums/generation-iii-internal-engine/460476-crank-pulley-came-off-threadlocker.html
