ticking noise??
Old Mar 5, 2006 | 07:02 PM
blackbirdls1's Avatar
does this affect the engine? is it bad long terM?
Old Mar 5, 2006 | 07:10 PM
Kyle C's Avatar
Mine sounds exactly like that. I always assumed it was piston slap. I routinely drive it like I stole it but it's not gotten any worse. Maybe I should change the cam and all of the other stuff while I'm at it.
Old Mar 5, 2006 | 08:54 PM
Last Call's Avatar
TOTM: January 2007
Originally Posted by barracuda68
I agree. Mine had the same noise and dealer replaced the o-ring and that cured the noise.
Was your noise coming from the back cylinders on the drivers side?
Old Mar 5, 2006 | 10:17 PM
Black_Bird's Avatar
Originally Posted by The Alchemist
Im curious, how did you know it went bad?? I'm not doubting you, just trying to understand what to look for. I've swapped the plug wires left to right, front to back, and it remains the same, the ticking is coming from the rear of the driver's side.
Because I heard all the stories about how it could be a bent PR, a bad plug wire, rocker, lifter, spark plug...about everything. I just went through and checked everything, starting with plug wires, and that just happened to be what was wrong. Took all 8 off and used a ohmmeter to measure resistance, the closer to 0 the better, and I had one old wire that was around 320 ohms. The rest were better with about 15 ohms. Dont know how just one went bad, but oh well. 8 new OEM plug wires all checked in at 5 ohms, and the car runs much better now.
My sound came from the rear of the driver's side too. You could hear it the best if you put your head down near the driver side front tire, in between the tire and the side mirror really.
Old Mar 6, 2006 | 09:42 AM
01formula6's Avatar
I have the same noise coming from the same exact location. Hopefully some new wires take care of it.
Old Mar 6, 2006 | 02:14 PM
C Murda's Avatar
so what would my noise be?? its like that ticking but not nearly as loud..is this normal? ive noticed my 91 Z28 makes the same noise but slightly louder but that also has 107k miles....
Old Mar 6, 2006 | 02:28 PM
NxLS1496's Avatar
i have the same noise as in the sound clip only not nearly as loud and you can only hear it when the hood is open or when im up against a wall where the sound reverberates. coming from the passenger side only... how bad is this?
